Question about Ovens
Code un6b on my control panel - Ovens
    Top Expert:
  • 9,472 Answers
What is the model number of the unit?
Posted on Apr 23, 2013
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
What is Kenmore double oven error code "F7" mean?
For the F7 error code:
What color is your key panel? Black or White?
Aug 06, 2011 | Kenmore Ovens
Flashing signal.....F7
Possible problem with your key pad or control board.
(Gain access to control panel)
Feb 10, 2011 | GE Profile JKP56 Electric Double Oven
IM GETTING F1
Hello there and thank you for using fixya
Well i wish i had better news for you but your f1 code is teling you that 1 of 2 things are failing.
First is that you electronic range controle has failed and needs to be replaced
Or that your touchpad has stuck and needs to be replaced .
Here is how to test to see which one it is
Remove the back panel from the oven controls to expose the controle panel .
Jan 24, 2011 | Amana AEW3530DD Electric Single Oven
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
good luck
Feb 27, 2010 | Whirlpool Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
The oven is flashing code F7 and keeps beeping
HI, this is an issue that concerns either the key pad or the control board.
May 15, 2009 | GE JKP27 Electric Double Oven
Ovens Logo
87 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
