Please see attached photo, this is what's
Please see attached photo, this is what's happening, Nothing happens when I strike F1 or F2 keys. Any suggestions? Thanks.
  • Computers & ... Master
  • 27,725 Answers
What are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
Posted on Apr 23, 2013
3 Suggested Answers
computus
  • 487 Answers
SOURCE: I had my battery run out, when I changed I get a
Hi, you will need to perform a windows restore using your windows CD. Insert CD in drive and select the appropriate option. You will not loose any of your work doing this.
Posted on Jul 30, 2010
  • 68 Answers
SOURCE: "Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Posted on Jul 20, 2011
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Just bought a new 120G HD for my Dell Latitude D600. The following error message comes up every time I turn it on: MEMORY ADDRESS LINE FAILURE AT 28000000 READ 00000000 EXPECTING FFFFFFFF DECREASING...
While the "memory loss" won't cause a major problem, you will be annoyed by the repeated message. A couple of things may be causing this. One, Windows changed the virtual memory size. This is an area on your hard drive that the computer uses to store stuff when the on board ram isn't large enough to handel it. the other thing that may be happening is you have a memory module going bad. You must remember that the hard drive size has nothing to do with the memory size. That is, your ram memory is what handles most of the processing of information. Your hard drive is just a storage place. Like a file cabinet in your office.
If this information was helpful, please rate it high. Thanks
May 24, 2011 | Dell Latitude D600 Notebook
Dell latitude cpi d300 xt keeps saying that the Primary hard disk drive 0 not found and it says that there is no bootable devices selected and when i hit the F1 key or the F2 key nothing happens please...
What has probably happened is, your hard drive is probably dead Basically its saying it doesn't see the drive so it can't boot. It could be either the drive or the motherboard.
May 17, 2011 | Computers & Internet
I had my battery run out, when I changed I get a message that says Strike F1 key to continue, F2 to run the setup utility. When I strike F1 nothing happens, when I strike F2 I enter the bios and I change...
Jul 30, 2010 | Dell Computers & Internet
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Pc won't boot
In your system actually the hard disk is not found because of some loose connection; so you just try to remove your hard disk and then start your pc and shutdown it after 1 minute. and then just attach your hard disk properly.
Check all the cable.
Mar 02, 2009 | Dell OptiPlex GX270 PC Desktop
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
Cannot boot my dell dimension 3000
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
