Question about HEWLETT-PACKARD G72250US Laptop
How do i turn on my bluetooth on my laptop - HEWLETT-PACKARD G72250US Laptop
  • 826 Answers
You had been provided a "fn" key on your keyboard, keep pressing the same key and tap the key which has the symbol made like Bluetooth.
You will be able to turn on the Bluetooth on your laptop.
Posted on Apr 23, 2013
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
Jun 10, 2013 | Acer Computers & Internet
Turn on bluetooth
Bluetooth on a laptop can be turned on by going to Control Panel and then Bluetooth and then you can simply double click it and turn it on.
Secondly, most laptops have a Bluetooth software and you can control the status of your bluetooth from that vary software.
Nov 01, 2012 | Packard Bell Computers & Internet
Where to locate Bluetooth on toshiba satellite
Turn on your WiFi/Wireless/WLAN, it will also turn on your bluetooth. Laptops which have bluetooth and wireless have combined function for bluetooth and wireless. You must installed bluetooth and WLAN combined driver to use this function.
Aug 22, 2011 | Computers & Internet
How to connect Microsoft Bluetooth mouse 5000
Please refer to the below KB article, this will help you.
http://support.microsoft.com/kb/952818
Please rate if you like..Thanks
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
I can not connect to samsung mobile to my laptops by bluetooth why
ensure you have installed bluetooth driver, turn it on, on the right below corner taskbar should appear bluetooth icon, right click it then add device, turn on your mobile bluetooth, the laptop should search for new bluetooth device, enter the passkey when given by laptop on your mobile, wait for awhile for adding new services
Good luck
Feb 03, 2011 | Samsung Computers & Internet
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
Please anyone solve my problem?
this problem generally occurs with blue tooth devices.
before reinstalling device driver
  1. shut down your system properly
  2. turn on your system.
  3. turn on the switch of bluetooth
  4. now try to reinstall the driver
  5. after installing driver restart your system.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Jan 06, 2009 | IBM ThinkPad T43 Notebook
HEWLETT-PACKARD G72250US Laptop Logo
55 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
