Question about Craftsman Sears Edger Manual Model 536.772320
Is there a blade guide for this model?
Lawn edger
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
I have a MTD yard man edger model 253 986 000 and I need a blade for it. What is the number?
It's either a 4 or 6 inch blade go to your local home center and they will hook you up bro. Good Luck! Don't forget the thumbs.
Aug 13, 2010 | Yard Machines Red Edger
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Seeking YardMan Landscape Edger Blades
Locate the model number of your machine and click here.
In the center of the page, click on "Launch Illustrated Parts Look-Up Tool".
Enter your model number and click "Search" to find your part number. You can order the part direct using "Quick Order" on that site.
Hope this helps.
Sep 29, 2009 | Yard Machines Red Edger
Change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Jun 12, 2009 | Yard Machines Red Edger
Are you supposed to sharpern the blades on the edger occasionally
Hello:
No. Edger Blades are Not Sharpened.
Respectfully
John
May 09, 2009 | Black & Decker Le750 Lawn Edger
Craftsman Sears Edger Manual Model 536.772320 Logo
14 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
