Question about Garden
Pressure washer not starting
Pull cord not coming back at all.
  • 460 Answers
Can you turn the motor over by sticking your fingers under the recoil and move it freely. If not something is locked up, either the motor itself of the pressure pump. Remove recoil and see if you can turn over by hand
Posted on Apr 24, 2013
  • freedbygrace May 03, 2014
    Standard problem; CHEAP pull cord recoil. The rope will come out of the recoil track and then it will bind. Design flaw they needed a guide to keep on recoil track. Take out 4 small bolts pull off recoil and rewind rope on recoil. You will need to wind tension back onto recoil and hold while you wind rope back on recoil. Tricky to get back on shaft without discharging but you can do it. A new recoil will not help the issue unless they have redesigned it.
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
motorhead427
  • 24 Answers
SOURCE: Pull cord is loose on my Honda 2500 Pressure
complete pull rope units are available for appx $23
Posted on May 30, 2009
SOURCE: pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Posted on Jul 21, 2009
  • 615 Answers
SOURCE: I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
Testimonial: "The problem was the governor spring. Thanks"
  • 251 Answers
SOURCE: My pull cord to my pressure washer is hard to pull
take out the spark plug and trying pulling it , if its still tight then you may have seized your pump ) , put a rag over te spark plug hole as there may be fuel/oil mix in the cylinder , check the oil in the engine , check the oil in the pump ( look for milkey white , if found then your pump back seals have gone )
Posted on Nov 19, 2009
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Water coming out of where the hose goes into the washer.
Maybe just a worn o ring inside the hose where it connect to the washer.
May 29, 2010 | Honda Pressure Washer PSI 3000
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Pull cord wont pull
ok i assume it is a gas powered pressure washer, if the pull rope wont pull out at all you either have a locked up motor or pump if it is out and wont go back in or recoil then the spring under the engine cover has either broke or come unwound.also if it wont pull out do youhave water applied to pump? if so turn off water and disconnect water hose to relieve pressure and try to pull it then then if it starts then apply water.
Mar 18, 2010 | Garden
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
Cannot pull start pressure washer. Cord will not
cord will not extend past 3 inches; just shut down after last use after 30 seconds.
Aug 31, 2009 | Garden
Garden Logo
402 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
