Question about Sony VAIO VGN-FJ270/B Notebook
Detect if my wifi card is destroyed or not
Hello
Sorry for my English , i am French
Here is the issue
I have a Intel wireless Wifi link 5100 card but I think this card is not working any more.
I want to check this point to see if I must send back my laptop to Sony
  • 3 more comments
  • yes I installed the updated driver
  • no answer to my question let me know
  • I would prefer to keep it at home because I used it everyday.
    Therefore I want to be sure that the wireless card is not working any more.
  • Hi
    could you precise me where I must go in the control panel ?
  • thank now I am sure that the wireless is not working any more
  • 15,935 Answers
Go to control Panel : System : Hardware manager.
Find your wifi device and delete it.
Shut down PC, and turn on.
O/S will detect new hardware. (if it does not detect, your card is faulty and warranty work is required)
Let the card re-install.
Retry.
Sony Laptops use an antenna behind the LCD, and it is common for the wires that run into the hing to be damaged.
Also, remove the panel from the underside of the laptop and remove/re-seat the wifi card. It may have been 'bumped' out of place.
Thanks for using FixYa
Posted on Mar 16, 2009
  • blueextc3221
    blueextc3221 Mar 16, 2009
    Sorry the correct location is :
    Start : Control Panel : Sysytem : Hardware Tab : Device Manager
  • Sony Master
  • 6,487 Answers
Under control panel look for System and then open it up and go to device manager and there you can check if the wireless card is working properly or not, check under network adapter if you can see the wireless card there if its not there it only means one thing its not working, but if its there right click on it and go to properties and check the device status...
  • Mark Gil
    Mark Gil Mar 17, 2009
    Ok good if the wireless is not working already you can go ahead and get a external wireless adapter that can be connected via USB so you can use the laptop tirelessly again...
  • 611 Answers
No just re-installed the driver of the card
  • Sony Master
  • 19,396 Answers
If you already re-installed the files, and ensured that you correctly activated the wireless card, but you still do not get the card recognised, then the hardware is probably faulty.
In this case you need to contact Sony to show them thet you already have done all the steps and you will get the unit repaired.
Si vous avez installe' les pilotes de l'ordinateur, et vous avez active' correctement le resau sans fil, alors vous devez de contacter sony pour reserver la reparation de l'ordinateur.
See:
Contact : Sony
Sony : Contact Us : France
  • 6,784 Answers
Hi, sending this card back for a factory repair will be the best decision at this point. the internals are damaged and will not be able to transmit or receive information.
Posted on Mar 13, 2009
  • Michael Masters
    Michael Masters Mar 13, 2009
    Click on the control panel and click on the icon labeled Network connections. there will be a connection that should say connected and firewalled. if this connection says disconnected, your card is ruined. if it reads connected. its OK.
    Sergeant:
  • 320 Answers
As the pc manufacturer will not support if the card is not getting detected.just check out any other same card on your system or check the card in any other similar system.also check out if the drivers are proper and the wifi connection turned on.to the local repair center of computer hardware and software get the card seperately checked to confirm the fault.
Posted on Mar 12, 2009
    Top Expert:
  • Sony Master
  • 77,517 Answers
Go to menu option in the control panel that says network and internet options, click that, it will then show that that u have a connection or not, if not and nothing else has changed then your card has a problem, I would also contact sony tech support first before you do anything, they will have to approve the return, they will ask u to do certain tests to verify the problem.
  • 916 Answers
If the driver is installed and the wifi is turned on the card may need to be replaced.
  • machadojr_fe Mar 16, 2009
    right click on my computer
    Click on properties
    click on the hardware tab on the top
    Click on device manager
    Click the + sign next to network adapters and please let us know what is listed there
  • 8,197 Answers
Go to your control panel to make sure the wifi is turned on.
  • Jyackle5
    Jyackle5 Mar 16, 2009
  • 583 Answers
If it is still under warranty.contact the sony support center as soon as possible to get it replaced.without trying to do any experiments that void the warranty.
    Genius:
  • 1,550 Answers
Better send to sony to get it repaired if it is under warranty .
    Brigadier General:
  • 3,614 Answers
may i know if there an error message appear when you try to use a net
  • micromaster
    micromaster Mar 12, 2009
    if the unit was still under warranty, it is better send it back to them for service and repair.
    any possible incidents may void the warranty, so better not to try do it yourself
  • micromaster
  • 412 Answers
Do you install the driver?
  • remoteserver Mar 12, 2009
    Most probably it have 2 problem:
    1. Wifi configuration problem
    2. Hardware problem.
What is WLAN 1591 Half Mini-Card?
1pcs Intel 5100 "Half" Mini PCI-E Wireless Card
Standard / Public Version fit in any brand laptop
Intel Mini PCI-E Wireless Card 512AN / 5100
  • Manufacturer: Intel Corporation
  • Manufacturer Website Address: www.intel.com
  • Product Model: 512AN_HMW
  • Product Name: 512AN_HMW WiFi Link
  • Marketing Information: The Intel WiFi Link 5100 Series is a family of IEEE 802.11a/b/g/Draft-N wireless network adapters that operate in both the 2.4 GHz and 5.0 GHz spectra. These adapters, available in both PCIe Mini Card and Half Mini Card form factor deliver up to 300 Mbps of receive bandwidth; in addition to providing a host of features that enhance today's mobile lifestyle.
  • Product Type: Wi-Fi Adapter
  • Wi-Fi Standard: IEEE 802.11n (draft), IEEE 802.11a/b/g
  • ISM Band: Yes
  • UNII Band: Yes
  • Number of Antennas: 2
  • Antenna Type: Diversity Antenna
  • Wireless Transmission Speed: 300 Mbps
  • Host Interface: Mini PCI Express
  • Dimensions: 1.06" Height x 1.18" Width x 0.13" Thickness
Jun 26, 2011 | ASUS A7V333-X (A7V333-X/L) Motherboard
'Intel(R) wireless WiFi Link 5100'
Look in Device Manager, under Network Adapters, and right click your wireless device. Choose Properties. Read the Power Management tab carefully and choose what you need to have happen.
Mar 08, 2010 | HP Pavilion dv6000z Notebook
Cannot turn on wifi on T400. Intel 5100 card
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Jun 18, 2017 | IBM ThinkPad G41 Notebook
C700 notebooks wireless driver for windows xp
Click here, follow instructions - HP will detect your exactmodel number and gives you driver list, pick from the list wireless driver, download it and install it.
Aug 01, 2009 | Computers & Internet
Can't get wireless connection to work
Is the wireless card driver installed and working?
Can the wireless card detect your Netgear Router and does it have a strong signal strength?
The Wireless card needs to be configured with the Netgear Router's SSID and encryption settings before it will communicate with the Netgear Router.
Let me know if you have further problems together with error messages.
Jul 31, 2009 | Computers & Internet
I have a Intel wireless Wifi link 5100 card but I think this card is not working any more. I want to check this point to see if I must send back my laptop to Sony
plug the card into your computer if its not internally installed...click START , controll panel, double click on system, select the hardware tab, then select device manager....scroll down to "network adapters" click on the plus next to it.
If there is a yellow ! or ? next to your wireless device the drivers are not present, corrupted, or installed incorrectly and need to be reinstalled for the wireless card to work properly.
If you find a problem there the driver is available here : http://drivers.softpedia.com/get/NETWORK-CARD/INTEL/Intel-WiFi-Link-5100-5350-Driver-12-2-0-11.shtml download it to your desktop, unxip it if neccessary and install. Please post again here if you need further assistance.
Regards..
Apr 02, 2009 | Computers & Internet
Sony VAIO VGN-FJ270/B Notebook Logo
148 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
