Question about Electrolux 18 in. ESL424 Built-in Dishwasher
Water not coming out of spray bars
I have recently acquired the above dishwasher when moving into my new home. Having cleaned the inside to get rid of musty smells and put a degreaser in to clean the dishwasher, I have found a problem. The dishwasher appears to not be spraying water from the spraybars. After the wash cycle had finished, there was still dry powder in the bottom of the machine. The sump at the bottom where the filter cover goes had filled up with water so I know water is getting into the machine. When I opened the door, there was heat coming from inside so I would assume the heater part of it is working. I have thoroughly cleaned the spray bars to make sure they were clear of obstructions prior to adding the powder. Is it possible there is a pump located somewhere in the sump bowl that may be broken? I really do not know much about dishwashers, so was wondering if it is worth fixing or just bite the bullet and replace? Any help would be greatly appreciated
  • 883 Answers
SOURCE: dishwasher fault
If you have tried to run any cycle and still end up with this problem, then most likely a failed timer unit. The next step is for the water switch to enact the next step which is to start the timer.
Posted on Jun 18, 2007
appldoctom
  • 311 Answers
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Posted on Jan 24, 2009
  • 13 Answers
SOURCE: Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Posted on Feb 13, 2009
  • 423 Answers
SOURCE: Dishwasher not cleaning properly but seems to be working ok
The main cause of poor cleaning when the heating element is not working is a failed heating element inside the base (sump)
A technician will be able to use a multimeter to check the element resistance.
Once the element is working again, I recommend that you use a brand name dish washing powder like Electrosol and Cascade. Never use a gel or tablet. Avoid cheap detergent.
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: Electrolux ESL4114 problem
my washing machine does fill up with water, sounds like the pump is trying to but no water is entering the machine, all pipes are correct any ideas any one.?????
Posted on Jun 25, 2009
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    I have a GE GSD6660 (from 2003) dishwasher that is not cleaning properly. I've tried a few types of detergants, gels, powders. I've cleaned the inside by hand, I've ran cycles with vinegar and baking...
    I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
    Dishwasher
    Spray Arms not Spinning
    How to Buy
    Appliance Parts Online
    A bad heating element causes many problems in dishwashers...
    Dishwasher Problems The
    Heating Element not Working
    Dishwasher Maintenance
    Dishwasher Residue and Film on Dishes
    heatman101
    Asker
    Apr 18, 2011 | GE 24 in. GSD6660GSS Built-in Dishwasher
    My dishwasher is filling up with water but it is not cleaning dishes. the lower spray arm is moving but has limited pressure. The top sprayer is barely moving. Water gets hot but seems as thought the...
    Dishwasher Spray Arms not Spinning
    How to Buy Appliance Parts Online
    Dishwasher Problems The Heating Element not Working
    heatman101
    agf23
    Sep 06, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
    Water squirts out but spin bars don't move
    Dishwasher
    How to Buy
    heatman101
    Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
    Jun 18, 2010 | Maytag 24 in. DWD1500A Built-in Dishwasher
    Arms not rotating
    heatman101
    xxx
    May 13, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
    My dishwasher has stopped cleaning plates properly. It makes everything wet but at the end of the cycle the detergent block is half dissolved at the bottom. I have just run a cycle and opened the door...
    heatman101
    kjh;lkhjk
    Mar 27, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
    The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
    heatman101
    vvbn
    Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
    Arms not rotating
    heatman101
    tter
    Mar 22, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
    Electrolux 18 in. ESL424 Built-in Dishwasher Logo
    63 people viewed this question
    Top Electrolux Dishwashers Experts
    Mike
    Starnley Johnwells
    Starnley Johnwells
    Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
