Hotpoint aqualtis washer dryer
The cycle selector knob on my washer dryer has become faulty (unable to select any cycle) can you advise?
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 333 Answers
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Posted on Nov 30, 2008
  • 86 Answers
SOURCE: a hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Posted on Jan 02, 2009
Samyfam
  • 379 Answers
SOURCE: I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Posted on Jan 13, 2010
SOURCE: PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD
the filter cap is jammed on my hotpoint bwd 129 whats the best way to get it of and clean the filter
Posted on Mar 15, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
I have an Electrolux EIFLSS55IIWO Washer. The chrome paint on the selector knob is chipping so Electrolux is sending me 2 new knobs for the washer and matching dryer. Can you please advise how to replace...
Good Morning David,
I see that you are looking to replace the selector knobs for your Electrolux washer, model# EIFLS55IIW as well as your matching dryer. This is typically not a common DIY job, and I do recommend contacting an authorized technician. However, I have found a link on the manufacturers sister website, which I have listed below, that provides a parts breakdown. It will also allow you to enter in the model number of your Electrolux dryer and locate the parts breakdown, as well as, a comprehensive listing of authorized techs in your area. Hope this proves to be helpful!
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=EIFLS55IIW0&User=&Search=Search
-Best Regards-
WP
Apr 07, 2014 | Electrolux EIFLS55IIW - Front Load Washer...
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I am looking for a manual for hotpoint aqualtis AQCF 852 BU. Can you help please?
I have the same dryer and went on the Internet and typed "Hotpoint Aqualtis" on Google. One of the alternatives is "Instruction Booklet" This when printed is the Manual for the dryer, in full.
Aug 25, 2011 | Hotpoint Dryers
Cycle selector not working
HI, when this happens, you will need to replace the switch. the mechanism will become faulty overtime.
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
