Question about Garden
2.0 C.I.D. what should 2 cycle fuel mixture be?
  • 7,482 Answers
Hi Arthur
40 to one is a good mix (40 oz gas to 1 oz oil)
Bud
Posted on Apr 23, 2013
Fuel mixture
if its 2 cycle the mixture can be several mixes. it should say on the machine. here are the following mixtures that I have- 16-1, 1 gallon of gas to 8 ounces of oil. 32-1, 4 ounces per gallon. 50-1
3 ounces per gallon and 100-1 2 ounces per gallon . most of my 2 cycles are 50-1. hope this helps.
Nov 29, 2015 | Garden
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
What is the fuel mixture ratio on a McCulloch Chainsaw MAC320? This is very old model
I went here hoping to find a written mixture and was disappointed.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/ed3f37336206f5a288256c2f001b074a?OpenDocument
I can tell you the OM for my Power Mac 320 model 600021H, serial 11-18555 says 40:1
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
I purchased mine used and have always operated it with a 50:1 mixture.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 01, 2010 | McCulloch Garden
Engine quits
16:1 is WAY too much oil if you are using decent synthetic oil. 50:1 will be much better - regardless of what it says on the gas cap. Oils are much better now than they used to be.
Contrary to popular beleif, more oil does NOT help a 2-cycle engine. The oil (which does not burn) displaces fuel in the mixture, so there's less fuel than there should be. That means the mixture is LEAN, and lean mixtures run hot.
Also, check for a partially blocked muffler (likely with that much oil in the mix). This will also make the engine run hot.
May 23, 2010 | Husqvarna Forest & Garden 125c 17"...
Fuel mixture for a McCulloch 3.4ci chainsaw
I found my owner's manual. Ordinary 2 cycle oil the mixture is 50:1
Jan 29, 2010 | McCulloch Garden
Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Jan 26, 2010 | Poulan Garden
What is the fuel mixture for the mcculloch 3216 chain saw?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 13, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel mixture homelite d3350b
Fuel/Oil Mixture
    Lou
Oct 09, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
