Question about Canon BubbleJet i550 InkJet Printer
Printer wont print anything in colour
Hi PRinter will do the black stuff fine, but no coloured objects, text anything will print. You can hear the printer sounding like it is printing but page is blank Thanks for advice Kanga2
  • w1mag Nov 10, 2007
    Same problem. Tried normal and deep cleaning, head alignment, new color ink tanks. Nothing helped.
  • Josacrin Jan 09, 2008
    Same problem, deep cleaning several times made no difference. The problem started when I refilled all of the ink and now only the black prints, with no trace of colour.
  • 32 Answers
Changing your cartridge would be better Arun
Posted on Aug 04, 2007
  • 58 Answers
Printer nozzle dirty/clog. Need new color ink. Goto printer menu and do the printer cleaning application there.
SOURCE:
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Printer only printing in black and white
you might have printer set to print in black ink only check in settings if not re install printer driver then print test page if the windows logo comes out in colour and the text black everything is fine
Jul 09, 2010 | Brother DCP585cw AllInOne InkJet Printer
HP Photosmart 3110 All-in-one not printing black ink but colour
have you found a solution to your black ink problem??? I am experiencing exactly what you describe, no error messages, I have reset the printer, alinged, cleaned etc but still not a single drop of black ink but all the colours are working fine. if you know what was wrong please let me know.
R
Jan 20, 2010 | HP Photosmart 3310 Printer
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon BubbleJet i550 InkJet Printer Logo
76 people viewed this question
Clive
Clive
old marine
old marine
Ekse
