Question about Brother GX-6750 Typewriter
Hammer not hitting striking - Brother GX-6750 Typewriter
  • 454 Answers
Hammer may be loose or the hammer solonoid may be bad
Posted on Apr 30, 2013
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Dt 200 motor extraction diagram
Take the nut off the swing arm pin and hit with a large hammer, be sure not to damage the pin's thread. Screwing the nut on until flush with the end of the pin can help protect the thread, and perhaps strike a hammer onto a piece of wood to protect the pin.
http://www.scribd.com/doc/86867524/Yamaha-DT200R-Service
Jan 09, 2013 | Yamaha Motorcycles
The striking hammer does not function
I know this is pretty basic but did you push thelever next to the print hammer to the back to latch the mech. to the rear?
DickyO
Apr 18, 2012 | Smith Corona Wordsmith 200 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Having trouble separating worn ball joint on lower control arm of 1999 4WD Z71 GMC Sierra. Have tried several size pickel forks, however the prongs of the pickel fork keep hitting the steering knuckle so I...
Have someone use a big prybar between the a-frame and the car frame while you smack the side of the ball joint with a hammer. This always works for me.
Sep 04, 2010 | 1995 GMC Sierra
MY KENT GAS HEATER WILL LIGHT WITH A MATCH SO GAS IS GETTING THROUGH BUT FLINT IS NOT WORKING TO IGNITE THE FLAME/GAS
Your igniter may well be a Piezo Electric device... a spring loaded hammer strikes a crystal and the crystal generates a high voltage which causes a spark. They sometimes break down mechanically and the hammer no longer hits the crystal. You can sometimes repair them (rarely) and sometimes buy a replacement unit.
May 09, 2010 | Heating & Cooling
Unable to remove heads on a '95 blazer 4.3 after all bolts have been removed. Please advise, thanks.
ifyour sure that all bolts are removed...and intake and all parts are removed...then take a piece of 2x4,and lay it against the head,and strike it with a hammer a few times. this should help pop it loose.just DONT hit the hed with the hammer!!
May 02, 2010 | 1996 Chevrolet Blazer
The hammer does not strike on the platen
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Apr 08, 2009 | IBM Office Equipment & Supplies
Cannot get wheel bearing to seperate out of the knuckle any tricks
Since you are likely attempting to remove the bearing/hub assembly, once it's unbolted, lots of wd 40 and a decent slide hammer works best. Otherwise try striking the wheel flange with a decent hammer, hitting it alternately on one side, then 180 degrees on the other side (opposite where you first hit it) this will prevent it from cocking and jamming as it comes out. You have removed all bolts including the one on the axle?
Mar 18, 2009 | 2004 Chevrolet Aveo
WON'T PRINT LETTERS
There is a clutch drive that releases the hammer to strike. Probably needs to be replaced. Unfortunately, probably not worth repairing.
Jul 03, 2007 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
76 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
