Question about Mantis Little Wonder Hedge Trimmer 2230S 2230S
Can anyone tell me how to properly place the trigger/lockout spring back into the handle of a little wonder mod #2330s?????
The spring has to be placed in handle in such a way that lock out trigger and gas trigger operate properly.
For some reason, this will not turn off when u release the handle
open up by holding trigger down then use flat blade to force red trig out with spring. You can then get the yellow handle to separate by inserting flat blade in to pop the yellow plugs. a big spring will come out at the same time and a white part with the washer in it.
Replace washer and you can refit in reverse order. put red trigger in place before pressing the handle back together. takes some force to press the front back in but snaps back in place. you can get a replacement washer for free from a co called skiffy. ask for a samples. great company. Hope this helps
Jul 17, 2014 | Hozelock 2684 Ultra 9 Premium Spray...
Putting handle back together it was leaky , cant find place for spring?
not sure but i am sure that its job was to push the trigger/throttle back in place so this should help you figure it out, more than likely behind the trigger look for a small protruding post/groove that would keep the spring in place--- you have pics to show now? that would help--- good luck questions just ask
Mar 30, 2013 | Powerwasher 80012 Universal Pressure...
Lockout Follower bar and spring location for Paslode 900420 Nailer
you can try going to paslode.com and downloading a breakdown of this tool. The lockout bar and spring go under the metal plate on the side where the pusher spring is. You have to remove the nose piece (2 screws) and lift the metal plate. Towards the bottom there is a slot that the spring goes in and as you are holding the spring push on the back side and lay the lockout bar in place. Replace the metal plate and hold in place to ensure these parts more freely. Reassemble tool. Let me know if you need more assistance.
Mar 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse 900420 cannot figure out where to put spring for lockout bar follower I know where the lockout bar goes. does not seem to be any space where the spring fits. can you tell me which...
it goes under the large plate, you need to remove the screws holding the nose in place (large black piece with screws on either side) sometimes this is a 2 piece part. Under the plate where the lockout bar sits is a small recess and you will need to start the spring and then push it into place with the lockout. Let me know if you need more assistance.
Aug 10, 2011 | RTO PasLode 900420 Impulse Framing Nailer
325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
Friend took my 900420 nailer apart to clean it and when he got done, had a small spring about 3/16" x 1" left over. Does anyone have a clue where it might go?
Thin spring?
Goes in-between the Follower Guide and Button.
There are several Coil springs used in a Paslode 900420 framing nailer.
1.In-between the Upper Probe and the Lower Probe.
(Safety device you depress so the gun will shoot)
2.Trigger
3.Lockout Bar
4.Follower Guide and Button
(There is a flat spring also. Goes in-between the Probe Stop and Probe Release)
Here let me show you,
http://www.paslode.com/uploadedFiles/Cordless_Framing_Nailer_Parts_Diagram_Schematics.pdf
Oct 17, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Karcher 1650 leaking water from trigger
i believe the spring is the actual trigger spring that pushes the trigger switch back in place and the water leaking out is probably a seal issue
Aug 25, 2009 | Karcher Garden
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Mantis Little Wonder Hedge Trimmer 2230S 2230S Logo
46 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
