Question about Garden
Craftsman model 917273220
Quits when you take brake off
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
Craftsman 50" 24hp , model # 917273220
You can eliminate the seat swith by unplugging it and putting a paperclip in to make a jumper and trying it.
Aug 07, 2012 | Craftsman Garden
Craftsman 5000 stalls when releasing brake when put in gear
The most likely suspect would be a bad seat switch or the plug to it has come off.To test it if the plug is still on the seat switch just stick a small piece of wire with then ends bared into each connector to "jump" the seat switch then if you can now let off the brake without it quiting the you know that you need to get one.
Aug 07, 2010 | Craftsman GT 5000 26 HP54" Garden Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" 19.5 briggs runs great , shuts off
check seat switch make sure it is plug in good you can unplug it and jump it with a jumper wire to see if switch is bad
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
