Question about Brother GX-6750 Typewriter
Hammer won't strike - Brother GX-6750 Typewriter
    Champion:
  • 204 Answers
1.If your unit is not printing check the ribbon cartridge to make sure it has not run out.
2.If the ribbon appears silver or gray install a new cartridge. Also make sure the ribbon is advancing in the cartridge.
3.Next make sure the black lever in the center of the carriage is pressed toward the paper. If not, press the black lever toward the paper to lock the daisywheel into place and reset unit by holding down the "CODE" key, while holding the code key down press the "REST / Q" keyand release both keys.
4. Try typing. If problem still exists contact an Authorized Brother service center. You may do so at 1-800-284-4357 or by visiting our website.
Posted on Jan 23, 2014
Hammer doesd not strike
There is a clutch system under the ribbon carrier that has to rotate to move the hammer, see if you can see if this part is rotating, also there is a spring that puts pressure on the hammer. If this clutch is not moving it may need replacement,, or cleaned with alcohol.
Apr 14, 2014 | Brother ML-500 Typewriter
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Jul 18, 2012 | Bosch Drills
The striking hammer does not function
I know this is pretty basic but did you push thelever next to the print hammer to the back to latch the mech. to the rear?
DickyO
Apr 18, 2012 | Smith Corona Wordsmith 200 Typewriter
HI,MY DISHWASHER DOOR HAS BECOME VERY STIFF TO OPEN ALTHOUGH IT CLOSES WITH NO PROBLEM. when I looked underneath the door grip handle, there's a little white thin skittle shaped pin .,......when I push...
Hello
Open the dishwasher door and inspect the latch mechanism for obstructions or immovability.
Clean out the door latch with a stiff bristled brush, and apply lubricant. Open and close the door to see if it now latches shut.
Check the door latch and strike plate alignment. Close the dishwasher door slowly and observe the door latch meeting the strike plate. Determine whether the latch is striking the plate correctly. If not, use pliers to gently bend the latch to meet the strike plate.
Gently hammer the latch to better align with the strike plate. Hammer carefully so as not to break the latch or dislodge it from its attached point. Open and close the door to see if it now latches.
Realign the strike plate. Loosen the strike plate with a screwdriver and slightly move its positioning to better align with the door latch. Tighten the strike plate and open and close the door to see the results.
Sep 07, 2011 | Dishwashers
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
The hammer does not strike on the platen
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Apr 08, 2009 | IBM Office Equipment & Supplies
How do i remove the magneto flywheel from a yamaha dt 175 1991 model? tapered or threaded shaft?
You will need a flywheel puller, ( dealer can sell you one > low cost ), and a hammer.
Remove the nut and washer holding the flywheel. Now screw the puller into the flywheel as far as it will easily go. Be sure to back off the pullers' center screw when mounting puller. Tighten the center screw REALLY tight then firmly strike the center of the puller screw with a medium size hammer. Alternate tightening the center screw and striking with the hammer. To tighten the center screw you will want to strike the screw handel with medium hammer force. A few blows with the hammer should pop the flywheel.
Please rate this answer after all is done. Thanks.
Mar 17, 2009 | 2006 Yamaha DT 125 X
Brother GX-6750 Typewriter Logo
96 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
