Question about Brother HL 5250DN Laser Printer
Specks on paper
Been working fine...today everything I print has specks on the paper. I moved the tab back and forth to clean the wire but they are still there.
Replace drum
Posted on Mar 13, 2009
Canon i3235
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Nov 26, 2013 | Office Equipment & Supplies
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
Copying problem
Vertical lines on the copy usually indicate a dirty drum or Corona wire. The Corona wire should be cleaned each time you replace the toner cartridge. This is done by moving the Corona tab back and forth across the wire several times to clear it of debris. You may also want to check the drum for debris. Holding the copied page to where it feeds out and lining up the line or mark on the page will give you an idea as to where the dirt may be. Best of luck with your printing issue.
Greg
Nov 04, 2009 | Brother IntelliFAX 2800 Laser Fax
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Brother HL 2040 out of paper light stays on
Sounds like it sensed this as a paper jam. If it is your Paper LED that is stuck on:
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Mar 14, 2008 | Brother HL-2040 Laser Printer
Dust on Drum...
I had this problem too. I took out the drum and vacuum the drum with a vacuum cleaner ( no brush ) while at the same time manually rotate the drum cyclinder. It worked. After a month or two, you might have to do it again. But everytime, it solved the dust problem.
Nov 23, 2007 | Brother MFC-7820N Laser Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Brother HL 5250DN Laser Printer Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
