Question about Onkyo HT-SR800 System
Audyssey The Audyseey Room Correction does not complete the cycle. Keep getting a Speaker Detect Error and yet all speakers are working fine. Freezes when it gets to the back left Surround. All wiring and set is fine.
2 Suggested Answers
Raveler
  • 36 Answers
SOURCE: Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Posted on Dec 31, 2007
I have an Onkyo TX-NR609 receiver that I'm very pleased with. I just upgraded my speakers to a set of Klipsche quintets with 400watt, 12" subwoofer. I don't want the text book answer o
You will need to go through the speaker setup menu and select the configuration and crossover frequency for the speakers. If you set to full range, your sub will not be engaged. Subs are only good at low frequencies, so use the lowest frequency for the crossover. (40-80Hz) If you have the audyssey microphone plug it and follow the directions to re-balance the equalization for the room and seating positions. If you don't use Audyssey, you'll need to tune all of the config setting manually. Some may be re-used if the distance is the same, but the loudness (+/- DB settings) and cross overs are probably going to be different for the new Klipsch speakers.
Jan 25, 2015 | Onkyo Audio Players & Recorders
Surround speaker
take back to be repaired under warranty asap this can happen. even if it's out of warranty they should repair for free if they stand by there product
Apr 10, 2014 | Onkyo TX-SR608 Receiver
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
This may not be an actual problem. I've observed after performing a successful Audyssey calibration that a few things seem odd. My large (Paradigm Monitor 11) front speakers are now considered 'small,'...
If it sounds normal, then yes leave them as they are.
But there may need to be an exception made.
The distances are set the way they are for the proper advance or delay in milliseconds of the sound arrival at the listening position.
The system calibrated your speaker settings based on how each channel's frequency responses measured at the listening position. Room acoustics and channel positioning greatly affects this. The settings it made in the system can be a best case scenario compromise that MAY not be good for your surround speakers as it can be delivering signal to them that they were not designed to handle; in which case it is best to increase the crossover value of those speakers.
Mar 29, 2010 | NAD T765
Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Feb 09, 2010 | Onkyo TX-SR606 Receiver
ERROR 12 - but all the speakers work. why?
The manual lists no error code 12. Check that all speakers are in the correct place in the room and that they are not out of phase (that on each speaker positive is connected to positive on the receiver and negative is to negative). Make sure that the mic is laying flat, and that the room is quiet. If using a sub woofer switch the speakers to small.
Jan 29, 2009 | Sony STR-DG500 System
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Jan 11, 2009 | Audio Players & Recorders
Onkyo 875 Audyssey will not detect
no solution from me but just to say i am having exactly the same problem - did you get anywhere with yours?
Jul 10, 2008 | Onkyo TX-SR875 Receiver
Onkyo HT-SR800 System Logo
24 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
