Question about Fahrenheat (FFH1614) Wall Mounted Panel Heater
Wiring Diagram I just want to make sure that before I wire this back up, that it is done correctly. I have 2 grn. wires to the themostat and a white and a blk. to the unit. Is there any place that I can see the wiring diagram? thanx Dave, pappy1958@aol.com
4 Suggested Answers
  • 10 Answers
SOURCE: not sure hooked up correctly
You should have a licensed electrician connect this unit for you.
That being said you need to supply 240v to the unit. You will need a true two pole breaker. (not a split or a twin) There should be two screws or lugs and two slots or clamps on the bus side. These slots must span both phases of your panel. You can measure the voltage across the two screws if you are uncertain, it should read 240v.
Next connect a piece of 12/2 wire to the two screws. Use the black and the white. Land the bare copper wire on the ground bus in the panel.
Then at the unit, land the bare ground to the ground screw and connect your 12/2 to the wires in the unit. You may find the wire nutted together. This is normal, and allows "feeding" the unit from either side. If you are unsure measure the voltage here also, across the white and the black. It should be about 240v.
Posted on Feb 09, 2009
nenalex2002
  • 134 Answers
SOURCE: I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Posted on Mar 22, 2009
milten1
  • 1304 Answers
SOURCE: I HAVE 3 wires from the wall: bLK, WHITE AND a
one set goes to your heater,,,,
red/black gr
the other set is either your voltage in, or your t-stat will control 2 units
Posted on Nov 04, 2009
Testimonial: "Thanks for the help, I appreciate it very much. "
Door speaker wiring colors
1995 Dodge Ram 2500
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 16, 2017 | 1995 Dodge Ram 2500
Looking for a wiring diagram for a range selector sensor plug for a 2004 chevy silverado 1500,4x4,4.8L with a 4KCD transmission
Connector Part Information • 15416722 BLK
• ASM Conn 12 F GT
Pin Wire Color Circuit No. Function
1 DK GRN 1433 Clutch Start Switch Signal
2-3 -- -- Not Used
4 YEL 772 Transmission Range Switch Signal B
5 BLK/WHT 771 Transmission Range Switch Signal A
6 GRY 773 Transmission Range Switch Signal C
7 BLK/WHT 451 Ground
8 WHT 776 Transmission Range Switch Signal P
9 LT GRN 275 Park Neutral Position Switch Signal
10 GRY 1524 Back-Up Lamp Supply Voltage
11 PNK 839 Ignition 1 Voltage
12 PPL 639 Ignition 1 Voltage
This all I could find, hope it is the correct one.
Apr 08, 2016 | Cars & Trucks
Need wiring diagram for power cord
green(ground) white (neutral) Black (power ) or hot
May 20, 2015 | Cars & Trucks
Wiring diagram compressor
from ecu wire color dk grn and white go to the compresor relay located under hood also ck 2 fuses to relay
Sep 04, 2014 | Cars & Trucks
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
Cooling fan rubbed into wiring harness breaking 6 wires, How can i match wires with common color codes? 6 wires 3 color codes 2 dk grn 2dk grn w white stripe 2 white.
If they are taped they shouldnt have moved far from where they need to be if they arnt it should be easy to trace them back and get them where they need to go.
Apr 06, 2010 | 2000 Oldsmobile Silhouette
Im need a wiring diagram for a stereo in a 1991 2500 4x4
GND- blk(thick)
PWR-ylw(thick)
P.ANT- blu w/white stripe
DOOR chime- orange
SPEAKERS
FrontL- brn wire and tan wire FrR-grn and lite grn wires
LRear-ylw and brn w/white stripe wires Rrear- dark & lite bl wires
Nov 03, 2009 | 1991 Chevrolet K2500
I am not sure what wires to use to hook up the trailer lights.
The wiring bundle in the right rear (jack) storage compartment contains the trailer wiring harness (if so equipped).
The color code is:
Brown- Running lights
Yellow- Left turn signal
Dk Green- Right turn signal
Lt Grn w/white stripe- GROUND
Lt. Green- back-up lights
White- CHM stop lamp
Orange-fused Aux
Blue- unfused Aux
as found on my 2002 Safari.
Apr 22, 2009 | 2002 GMC Safari
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Wiring diagram for radio
if your truck still has the wire connectors for the radio harness then your best bet would be to purchase the plug in adapters from wal-mart or local stereo shop,it should only cost about 10-15 bucks and would clarify your connectivity issues.or get a test light and at least determine power & ground wires then run new speaker wire
Jun 28, 2008 | 1988 Ford Ranger
Fahrenheat (FFH1614) Wall Mounted Panel Heater Logo
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
