Question about Plantronics Discovery 975 (8164001 P) Bluetooth Headset
Garbled sound Sound is garbled when using. Sound good when use speaker phone instead.
Our 2 year old Sanyo 50 flat screen has a garbly, audio sound. Is there any way to fix this?
as sanyo is taken over by panasonic, warranty status is therefore unclear, in most countries it is 3 to 5 years warranty, do not meddle with it, check warranty status first here, choose your region:
http://panasonic.net/sanyo/
take serial number, part number and year of manufacture, fill form and you will have info if it is still under warranty in your country/region. if it is under warranty - call numbers provided and arrange it.
if there is no warranty for your unit anymore, any tv technician will help you.
hope this info will help you - do not forget to vote...
Feb 12, 2015 | Sanyo Televison & Video
Ipad 3 sound garbled
Is there difference between speaker and headphone jacks ports
Not all computer headphone jacks will work with speakers. So, it would appear that your computer is one them. Read the article I've linked.
Jun 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to troubleshoot speaker
Hello sir, Hi!, the garble is caused by two things, 1. a bad speaker, 2. a bad power amplifier IC.
To test the Speaker,
Remove the speaker out from the TV, (this needs disassembly stuff) test it using any available portable amplifier. or radio, OR replace the speaker with the same size.
If this does not solve the garble sound, replace the power amp IC. (this really needs skills in electronics.) thats it.
Apr 27, 2010 | Televison & Video
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
Garbled sound
Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
Mike
Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
Distorted Sound on Speakerphone
you need to have the speaker replaced.
Aug 06, 2007 | Motorola Mobility RAZR V3
Plantronics Discovery 975 (8164001 P) Bluetooth Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
