Question about Mathsoft Computers & Internet
What is 46.8 as a fraction in its lowest form
  • Mathsoft Master
  • 7,993 Answers
234/5
Posted on Sep 14, 2015
2 Suggested Answers
ColdTattoo
  • 219 Answers
SOURCE: write the ratio as a fraction in lowest terms. 7
multiply each by 5 to get whole numbers. your ratio will be 35:26
Posted on Feb 18, 2010
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
Can you help me on this question?
This answer is correct. 4/12 divided by 2/2= 1/3
The reciprocal of 2/2 is 2/2
Then you multiply straight across and reduce to get 1/3
Mar 01, 2015 | Miscellaneous
How do you find the common denominator
The denominator is that number on the bottom of a fraction, so with 2 different fractions you want to get them in a form where they have the same denominator. Often you will be trying to find the lowest common denominator.
The usual procedure is to multiply one denominator into the top (numerator) of the other fraction. Then repeat this process with the denominator of the second fraction multiplied into the numerator of the first fraction. Then multiply the 2 denominators together and the result is the denominator now of both fractions.
Eg 2/3 and 5/7 become
14/21 and 15/21
Sometimes further simplification is possible where one fraction has a denominator which is a mltiple of the other. eg
2/3 and 5/6
In this case you only need to multiply on the first fraction
4/6 and 5/6
Aug 13, 2014 | SoftMath Algebrator - Algebra Homework...
Changing 80% to a fraction in the lowest term
You have to be careful. 80% is in fact 0.8.
Turn the calculator ON.
Enter the number 0.8
If your calculator is set to Write-View you will see the number displayed as a stacked fraction 4/5. If it is already in this form, press the key marked change with two arrows. The display should show a fraction.
If your calculator is set to LINE, you will see 4r5, where 4 is the numerator and 5 is the denominator.
The key marked change allows you to change displayed result from decimal to fraction and from fraction to decimal. When a number is converted to a fraction, it will always be a fraction reduced to its simplest terms.
Jan 14, 2012 | Sharp ELW535 Calculator
What is the method to write fractions into their lowest forms....for eg.... 10/15?
By fraction I understand that the numerator and denominator are both integers. The way to simplify it by hand is to look for the greatest common divisor of the numerator and denominator and simplify by it.
For example 15/27=(3x5)/(3x9). The greatest common divisor of 15 and 27 is 3. Simplifying by 3, you get 5/9
May 22, 2011 | Office Equipment & Supplies
61/82 as a fraction how to reduced to lowest fraction 1/?
61/82 is already reduced to lowest terms since 61 and 82 have no factors in common (other than 1). In fact 61 is a prime number so it has no factors other than 1 and 61.
Nov 13, 2010 | The Learning Company Achieve! Math &...
Write the ratio as a fraction in lowest terms. 7
Feb 18, 2010 | Core Learning Fractions Step-By-Step...
When I divide, I get a fraction. How do I get a decimal
If your calculator is configured to be in MthIO, the fraction that is displayed is always reduced to its simplest form. (The denominator is the smallest possible.)
If you are adding fractions, the result is also a fraction in its reduced form.
If you want to convert a fraction to a decimal number, press the [S<=>D] key.
To set MthIO: Press [SHIFT][MODE] (SetUp) and select [1:MthIO]
To set LineIO: Press [SHIFT][MODE](SetUp) and select [2:LineIO]
In LineIO, all results are expressed in decimal format.
Jan 26, 2010 | Casio FX-115ES Scientific Calculator
61/82 as a fraction reduced to lowest fraction
This fraction is already reduced to its simplest form because 61 is a prime number: a number that can only be divided by itself and by 1.
Hope it clarifies things.
Sep 07, 2009 | The Learning Company Achieve! Math &...
Computers & Internet Logo
142 people viewed this question
Top Mathsoft Computers & Internet Experts
k24674
Michael Cummings
Level 1 Expert
Bapco
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
