Panasonic television set
On and off switch not working
    Sergeant:
    Champion:
  • 245 Answers
Get a new switch or bring ur tv set to a repair shop...
Posted on Mar 12, 2009
Panasonic 1080i 3 blinking lights. Removed the
3 blinks is indicating that the convergence has shut the set down. The PT53WX53 convergence repair kit from www.tvrepairworld.com works for your model and should solve the 3 blink issue.
Mar 06, 2011 | Panasonic PT-56WX53 53" Rear Projection...
HI I have a Panasonic Blu-ray Disc Home Theater Sound System Mod SC-BT735 which works fine manually but the remote will not work although the DVD is receiving the signal. Every time that we press a...
That is because the remote control is set to remote number 2. Set it to remote number 1 and all will work or set the switch on the Blu Ray to number 1.
Hope that helps.
Feb 27, 2011 | Panasonic Televison & Video
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Cant get dtv to work on panasonic
Do you live where DTV is available? Does the TV support DTV? Are your signal levels adequate? Have you switched the set to its DTV setting? Have you run an autoscan?
Jul 17, 2010 | Panasonic Televison & Video
Panasonic Model TC - 32LX60 can't switch to 1080i again manual doesn't tell me
The resolution is not set at the TV, the video source sets what the TV will display, 720i/p in = 720i/p display. May be you are talking about the aspect RATIO setting, 16:9, 4:3, zoom1, 2, 3.
It works the same as youe PC monitor, the resolution is set at the PC not at the monitor.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 17, 2010 | Panasonic TC-32LX60 32 in. LCD Television
Panasonic TH42PZ85B troubleshooting standby light flashing red and TV will not come on line?
Have exactly the same problem. Standby light flashing twice in 1 second then off for 5 seconds but will not switch on. This after switching off on the set following around 1 hour use.
Switched all power to set off for around 30-40 minutes
Jul 02, 2010 | Panasonic Televison & Video
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
TV switching imputs
Go to the main setup screen and check your defaults. You might have it set to go to a certain input after a set amount of time.
Jan 20, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Panasonic PT-47wx49E
does the led indicator blink? If so how many times does it blink?
Sep 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
