Question about Goodman CKL36AR36 Air Conditioner
Where is the capacitor
My unit makes a very loud squealing sound off and on. I believe that it possibly is the capacitor. Where is it, and is this something I can repair myself? I purchased this home with unit recently. This home was empty for years. I went to the Goodman website, and am unable to find the manual. Do you believe this could be the problem, and if not what? Thank in advance for your assistance.
  • 31 Answers
This is NOT the capacitor! I would not go opening up the control panel unless you know what you are doing as the voltage in there will put you to sleep permenantly. It sounds like the fan motor is about to go out. The unit will have a safety cutout switch by the unit. Metal box with either pullout or throw switch. Disconect unit using this, open top cover by unscrewing the holddown screws. Motor will have serial #, voltage, hp rating, rotation direction all of which you need to order a new one. remove wires, labeling them as you do so. Loosen mounting bracket around motor. Fan can be removed by loosening the set screw on the motor shaft. Measure how far from motor the fan is and make note as it needs to be put back in the same position. Set fan to side and remove motor from housing bracket. Put new on back in reverse. My BEST advice? Hire a pro for this!
Posted on Apr 23, 2013
  • 46 Answers
SOURCE: OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
Posted on May 25, 2009
  • 66 Answers
SOURCE: No "Cold" No "Good"man.........
Your on the right trackbut if the outside unit is running fine I have to say no :) . Disconnect the power from the unit and look for visible bulging in the Capacitor(will look like a frozen coke can) If no visible signs take your multimeter and check the micro farads fo the cap if 10% less than rating replace. Also look at the terminals conected to the compressor they may be melted . I would like to know the Capacitor ratings and what your measurments were.
Posted on Jun 30, 2009
hiltonjug
  • 612 Answers
SOURCE: Just had a new 3.5 Ton Goodman GSZ13-13 SEER,
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Posted on Oct 13, 2009
  • 415 Answers
SOURCE: 3 year-old Goodman compressor/heat pump terribly loud @ start
Without being there to see it and have only your description in front of me, it sounds like the fan blade could be out of balance.......but it sounds more like a loose fan blade hub. Most Goodman units offer a minimum 5 year parts warranty. The Labor warranty is questionable, but the installing contractor or the Goodman Distributor should be able to give you that information. Of course this would cover manufacturer problems and not physical damage. As far as a history of this problem with Goodman..........I've seen it with every brand. If there is a problem getting it under warranty, you might be able to purchase the blade yourself. Before replacing the fan blade, I recommend disconnecting the motor wires from the contactor, tape off the ends and remember exactly where they were attached.....then start the unit to see if the noise is still evident, if so, it's probably your compressor. I recommend a certified repairman....not the one that quoted you $800.00. If you hear only the compressor start up and not the loud noise you are discribing, then try replacing the blade first.
I hope you find this information to be very helpful to you. :-)
Posted on Mar 17, 2010
Testimonial: "good advice"
  • 1033 Answers
SOURCE: Very loud "squealing" noise from fan blower for
Hello, if you cannot turn the fan by hand then the motor is shot. However, when power is applied to the motor and it starts after you give it a push then its the capacitor. Whenever you replace a motor tje capacitor must be replaced aswell because the microfarad rating of tne capacitor may have changed.
Posted on May 31, 2011
How do you drain and refill the power steering unit on a 2004 kia Sedona mini van?
you never have to drain it but never let it run dry the loud squealing sound is prob your belt which may need the idler pulley replaced , this is my quess
May 26, 2015 | 2004 Kia Sedona
What is causing my speakers to make a loud squeal sound constantly?
I bet it only does it when the car is running and kind of increases with acceleration of the vehicle? You can actually go to your local automotive parts store and buy a capacitor that eliminates that sound. The capacitor goes between the power source and your radio and stops the high frequency sounds created by the alternator from coming through your speakers, I hope this is helpful to you. Sam's Mobil Automotive Services Knoxville. TN
Jun 12, 2014 | HP Pavilion Computers & Internet
My washer makes a loud squealing noise when it spins, what is wrong
Hello Kathy McAlister - Typically, when the washer is making or produces a squealing sound is due to an overloaded load. I recommend running a cycle with less clothing. If issue continues, then consult with a professional to accurately pinpoint any potentially more serious issue like a faulty belt or a bearing/pulley suspension problem. The washer could possibly have broken something off in between the tub and outer portion of the unit.
Feb 23, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire dishwasher model number FDB4050LHS1 making a loud squealing noise
Usually this is the drying time of the cycle. I would have a professional look into the blower assembly and heating elements of the unit.
Aug 25, 2012 | Dishwashers
May 30, 2011 | Goodman CKL42AR42 Air Conditioner
A loud squeal evrytime the unit sits for a couple
if you have to spay the belt to get it to stop then the belt is most likly streched or bad. take the belt off and turn all the free spinng pullys alt,power steering,a/c,ect if all spin good with no horible sounds then replace the belt , if any turn hard then this is what the problem is.but im betting it's the belt
Feb 10, 2010 | 1999 Dodge Durango
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
May 05, 2009 | Amcor PLM16000 Portable Air Conditioner
GE Heat/Cool model AJHS10DCBM1
OK I will be looking over the manual. Now that squeal sounds like the squirrel cage fan scraping the housing around it. Those units are so tight fit they can be twisted one way or tightened a little to much they scrape. I love them for there silence win they work right but hate them because my hand are too big to move things around inside them. Stay in touch I will be looking around while
multi-tasking today- I'll be here!
Feb 02, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Goodman CKL36AR36 Air Conditioner Logo
43 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
