Question about Briggs & Stratton Garden
Gapping plug spark
What is the gap specification for a 7.75hp engine
  • 5 Answers
SOURCE: What is the spark plug gap setting for a LAWN BOY
from what I have seen so far the gap is .30 for all manual start 2 cycle and 4 cycle and .35 for electric start
Posted on May 05, 2010
kel1guy2002
  • 3740 Answers
SOURCE: spark plug gap for honda 160cc engine
The Gap is 0.028 and the Spark Pulg should be an NGK BPR6ES.
Posted on Jun 13, 2010
Service Dude
  • 201 Answers
SOURCE: spark plug gap size
1.3mm
Posted on Jan 03, 2009
  • 196 Answers
SOURCE: Spark Plug gap settings.
Look on you're emissions tag under the hood they should be on there.
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: spark plug gap keeps closing on 2 stroke engine
it could be the spark plugs are to long and the piston is hitting the glug
Posted on Mar 22, 2009
Spark plug gap for NGK BKR6EK
this is bogus question, sorry\
sparks plugs are gapped to a specific engine
no car stated, no year, no engine.
so no joy.
it also varies by engine class
(compression ratio, turbo or not, and what year,)
older cars had weaker sparks and narrow gaps.
end tech.
Dec 16, 2016 | Cars & Trucks
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
What is gap
Hi, Mike pertaining to engine spark plugs, "GAP" is the distance between the positive and negative electrodes at the base of the plug and is measured in thousands of an inch or mm by using a round pin gap gauge or flat blade feeler gauge. Every engine manufacturer has a specific design-size-heat range- gapped spark plug. Gaps will vary depending on engine brand. Gap is also referred to in engines using a mechanical "POINTS" ignition system instead of electronic ignition (what is the points gap) for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
How to Inspect and Adjust the Spark Plug Gap NGK BOSCH CHAMPION N3 DENSO
http://www.jsesc.com/mfg_docs/ste/Spark_Plug_Application.pdf
Points and Condenser Setup wiring Setting Gap Cleaning Points Setting...
Multi Ground Spark Plugs NGK Spark Plugs Tech Video
Mar 12, 2016 | Motorcycles
Need magneto gap specifications between the flywheel and magneto.
I don't know the specs, but a business card inserted between the two always works for me.
Oct 12, 2014 | Garden
A gap tool is what you use to set the gap on your spark plugs...The gap is the tiny space on your spark plug that allows the plug to fire the engine. When you buy the spark plugs at the auto parts, the spark plugs come pre gapped for your specific engine. I usually check them to make sure.
Aug 03, 2014 | 2003 Suzuki VZ 800 Marauder
What is the gape for the plugs"?"
for the 2.2 liter engine:
  1. Gap the spark plugs to 0.045 inch (1.1mm).
for the 2.4 liter engine:
  1. Ensure the spark plugs are gapped to specification: 0.042 in. (1.06mm).
for the 3.5 liter engine: Adjust spark plug gap to 0.043 inch (1.1mm).
Jun 26, 2014 | 2006 Saturn Vue
Im looking for spark plug gaps
If you have already bought the repair manual for this specific vehicle, it will tell you in Chapter 1 what the gap should be on the spark plugs. This is a per specific vehicle/ engine.
Aug 30, 2011 | 1997 Jeep Grand Cherokee
1999 dodge ram 1500 5.2L timing,plug gap,firing order
You will find the spark plug gap and timing specifications listed on the vehicles emission label under the hood, and those specifications are the ones to be used on that vehicle and engine for that year, and no other specifications should ever take precedence over the specifications listed on the vehicles emission control label. Here is the firing order diagram for that engine, let me know if you require any further assistance, and I an curious as to how you got taken for $2,000.
Jun 16, 2010 | 1999 Dodge Ram
Need to know the spark plug gap for ryobi model no. ry60511A
Ryobi RY60511A
Champion plug RCJ6Y - gap is .22
I have original manual.
Apr 18, 2009 | Ryobi Cultivator
Spark plug gap on a 1992 Gmc Sonoma 4.3L V6 FI
Usually somewhere on the engine or in the engine compartment, there is a sticker with the engine specifications. The spark plug gap should be included. If not .032 or an inch should be close.
Good luck
Jun 26, 2008 | 1992 GMC Sonoma
Garden Logo
104 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
