Question about Konica Minolta bizhub Office Equipment & Supplies
Fax error R02
Not receiving faxes
CompuGuy44
  • 432 Answers
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Posted on Jun 25, 2007
  • 24 Answers
SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Posted on Sep 25, 2007
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
SOURCE: Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Posted on Feb 24, 2009
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 1010 fax - only receives first pages of a fax
Do you have DSL, or any other type of digital phone line.
Usually this is caused by a "noisy" phone line; some sort of interference.
Sep 23, 2008 | HP 1010 Plain Paper Inkjet Fax
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Error 0495 - Receiving Faxes
Might be a problem with speed of the fax. See related question.
Jul 11, 2008 | Epson Stylus CX9400 Photo Printer
Comm. Error
Jun 25, 2007 | Canon L120 Fax Laser Printer
330 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
