Question about Kenmore Washing Machines
Sears Kenmore 110.82872100 washing machine won't drain
I started by replacing the lid switch. Washing machine still won't drain. Occurs at first (intermediate) drain.
  • Kenmore Master
  • 3,361 Answers
Remove the drain pump and look for obstructions on the pump.
Posted on Mar 12, 2009
Any recalls on Kenmore Model # 110.20022012 Washing machine?
I think that your "LID Switch" is broken, go to www.sears.com/parts and put your model number in and you'll see the lid switch listed.
Aug 28, 2014 | Kenmore Washing Machines
Kenmore washer lid switch
Yes all washing machines have these to prevent some one from opening lid and inserting hand or anything else while machine is spinning , once lid opens machine seizes to operate .
Oct 02, 2013 | Kenmore Sears Washing Machine Lid Switch...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
How do you replace the lid switch on a Kenmore 70 series washing machine
Hi.
Check for drain blockage at the filter. Check setting of drain hose at the back. If there is no drain problem check pressure switch, central control unit and pump motor.
Here a tip talking about drain and spin problems: http://www.fixya.com/support/r7775926-no_spin_tip_all_washers
Nov 13, 2011 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Want drain
hi..
sounds like the coupler has stripped on you kenmore ? if so go to sears.com and you can pull up a diagram of the machine and see its placement
Jul 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Washing Machines Logo
101 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
