Question about Transmission & Drivetrain for Ford F150 Flareside SuperCab
2000 f150 transmission slips in overdrive
    Master:
  • 665 Answers
Usualy, this problem can be fixed by a simple fluid change. When you check your fluid, the color and smell tell the issue. Good fluid should be clean and redish in color. The smell should be slightly sweet like antifreeze. Bad fluid is dark brown in color, and smell like it had been burnt. A clear indication that it is time for a fluid flush. Good luck and I hope this helps.
Posted on Apr 22, 2013
Transmission over drive is causing the transmission to slip. When I take off the overdrive the transmission functions normally but it uses much more gas.
Roger, that doesn't even make a whole lot of sense to me. If the overdrive is causing the transmission to slip, wouldn't it also cause the fuel mileage to go down? Are you sure the transmission is slipping? Or is the transmission simply shifting in and out of overdrive? If it is, is it shifting at the proper speeds? Driving at around 40 - 50 Mph will sometimes make the transmission go in and out of overdrive repeatedly. This can be perfectly normal.
Have you checked your transmission fluid level?
Is your overdrive off light flashing? If the transmission is actually slipping the OD OFF light should be blinking at you to let you know there is a transmission problem. Either that, or the Check Engine light will be coming on. In either of these cases, you need to scan your onboard computer network for possible fault codes.
Mar 06, 2012 | 2000 Lincoln Town Car
My 2001 ford overdrive light is blinking and the first gear slips when in drive what can in be do i need to repair the trans?
The overdrive light flashe becuase it indicates an electrical fault within the system........have the checked the fluid level and conditoin.....it should be checked in park, after going thorugh all the gears allowing the oil to circulate the transmission (at idle)....and it should be a cherry red color...if it is a brown color and smells like it is burnt, you may have further damage within the transmission itself
Oct 29, 2010 | 2001 Ford F150 Styleside SuperCrew
Transmission slips out of overdrive when driving on the highwayat high nspeed
you need a rebuild, your overdrive clutch is worn out. do not drive in overdrive until the trans is rebuilt.
Oct 23, 2009 | 2000 Dodge Ram 1500 Truck
Transmission shifts ony 123 no overdrive, it slip in overdrive
sorry to say this trans has to be removed and rebuilt seems like od clutches burnt out-do you tow heavy trailer with truck as you have to tow with od off(push button on shifter)
Oct 05, 2009 | 2001 Ford F150 Styleside SuperCrew
Transmission neutralizes when taking off in drive.
That's probably why it's lurching. It's try to shift down. The valve body is a reasonable suspect. Was the balve body yorgued? Are the ck balls in the proper circuits? If the valve body has any loose bolts, the gaskets need to be replaced again. Good luc
Jun 08, 2009 | 2004 Ford F150
1992 Mitsubishi Eclipse transmission slips in overdrive
well the low cost way to go first would be to try and change the trans fluids. If the problems still remains the it may be an internal problem
Feb 25, 2009 | 1992 Mitsubishi Eclipse
Overdrive light on gear shifter is blinking?
The overdrive light blinking indicates a code has been stored in you computers transmission control module, the cost will depend on the problem, some have had problems with the torque convertor clutch slipping, could be more major, get the code pulled out and I can provide you with a more complete answer. -Jared
Nov 13, 2008 | 1996 Ford F150 Regular Cab
Overdrive transmission
O/D light flashing is computer indicating an issue with the transmission -no surprise. Make sure the transmission fluid is still good (dosn't smell burnt, right level). Slipping could be the TCC (torque Converter clutch) - not a cheap part - but would only really slip in 4th gear (above 40 mph). Slipping before that could be numerous things in the trans (low fluid pressure, torque converter issues).
I would be tempted to replace the fluid anyhow, but there is a chance an expensive issue is starting to arise - and replacing the fluid on a failing transmission could cause it to fail 100% (or can fix it nearly 100%). These can be touchy transmissions, too much DIY without the right diagnostic tools can be bad. Not what you wanted to hear, and not an expert, but have had some expertise with these.hope that helps.
Jun 10, 2008 | 2000 Mazda Protege
Transmission & Drivetrain for Ford F150 Flareside SuperCab Logo
140 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
