Question about Toys
Blade MQX QUAD-COPTER
The problem is achieving stable flight. And now to understand how and. Which trim buttons affect which props and how
    Master:
  • 665 Answers
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Posted on Apr 22, 2013
How to change flight mode from a 2 back to a 1 setting this affecting my flight control.
Push the "Fine-tune Strafe left/right" (located under the right joystick) towards the right and hold it in postion, then turn the controler ON.
May 02, 2015 | Protocol Manta 4-Channel Radio-Controlled...
The instructions are vague on trim tabs I'm not sure wich ones control what . Is there a more detailed instructions besides the ones that came with the copter?
check their website for more detailed instructions. But trim tabs are used to bring the rudder, etc to a neutral position. Play with the tabs and look at your copter to see what it affects is the quick way.
Jun 13, 2014 | Heli-Max 1SQ Quadcopter RTF SLT 2.4GHz
Instruction manual for UDI U187A says left front white blade should turn clockwise,right white blade should turn counterclockwise,left bottom should turn clockwise,right bottom should turn counter...
Out of the box my sons U817a had 2 blades rotating in the wrong direction as well. This is one example of how poor the provided directions are. First, the directions are written in Chinglish, second, they give no repair procedure for blades installed incorrectly at the factory. I'm just going to return mine. Obviously, flight was out of trim in this configuration. Hovering was all but impossible.
Feb 22, 2014 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
Estes quadcopter does not fly up; only left, right, back and foward
How old is the quad? Maybe the gear shafts are dragging. (Not spinning at full potential)
Jan 10, 2014 | Estes Dart Quad Copter RTF ESTE4605
Trim problem. Won't hover ,just crash
Try to operate while holding it... Or have someone else holding it, if you can feel where it's want to go while sticks are in neutral, trim it the opposit way. Good lock Have you look at gyro gain? Try to lower it as too fast makes it instable.
Jan 03, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Ah64 lower blades won't rotate
check all the trims on the tx
May 17, 2017 | Toys
After a minimal crash the bottom blade is not spinning , but the whole copter is trying to spin.
probably you bent a piece near the shaft and it is stopping the prop from spinning but since the motor is still spinning it still tries to spin the other side of the shaft(the copter)
Dec 21, 2011 | LawlMart iPhone Apps
Triming
HI,
You could trim the speed of the motors.
Pull out the canopy cover/housing, on the board you would see two trimming screws, the front would be for the rear motor and the other one for the the main motor.
Adjust the trimmer for the rear and test the lift, test flight the copter, if it stays stable and the tail did not move to any direction, that will be the perfect adjustment.
You're ready to fly!
Nov 23, 2011 | Air Hogs Havoc Heli Helicopters
Does the rc jumbo dragon fly helicopter fly forward or just up and down? Any help would be greatly appreciated. dave
This is a two channel Dave, meaning that the radio is only capable of up or down, or to spin the tail left or right. You will get forward momentum out of it because the design of parts like the removable cockpit housing, or the weight of the battery pack way out front give it "ballast" for forward momentum.
This is very similar to the way the small indoor models work. You will need to get the copter trimmed out to see this happen. Keys to stable flight are to stay at an altitude that you prescribe,
Dec 19, 2010 | Jumbo RC JUMBO HELICOPTER
Toys Logo
740 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
