Question about Toshiba Satellite® A205-S4597 PC Notebook
My touchpad doesnt work.
Need directions for windows vista
    Sergeant:
    Champion:
  • 245 Answers
Go in contact with toshiba customer help service ...hopefuly they will get ur touch pad working and tell u what to do
Posted on Mar 12, 2009
Right side of the mouse pad doesnt work
Unfortunately your touchpad is damaged and will need to be replaced. Most likely this will mean replacing the entire bottom chasis of the unit.
Nov 06, 2013 | Compaq Presario Cq56-219wm
Touchpad Scrolling
The scrolling feature on a laptop touchpad can take some getting used to, which causes some users to disable the feature.
Whether scrolling was intentionally turned off or never enabled on the laptop, it can easily be turned on from the "Mouse Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and select "Control Panel." Select "Classic View" in Vista if not already displayed. Double click "Mouse."
You may also access "Mouse Properties" in Vista and Windows 7 by clicking the Windows logo and typing "Mouse" in the search box.
Press "Enter," then click "Mouse" when the search is finished.
Select the "Hardware" tab.
Select the touchpad and click "Properties."
Click "Change Settings" if the settings aren't displayed.
Click the "Device Settings" tab in Windows 7 and select the touchpad.
Click "Settings."
Click "Virtual Scrolling" in the touchpad properties window.
Click the boxes next to each "Enable Scrolling" box and click "OK." Scrolling is now turned on for your touchpad.
May 26, 2013 | ZT Group Cisnet PC Desktop
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Acer Aspire 5102 I've reinstalled win 7 on my acer,and now my touchpad scroll button between left and right buttons don't work.how can i fix that?
Hi! Just head over to this page and select the "Synaptics Pointing Driver" under Drivers and Utilities for Windows Vista. It seems Acer doesnt provide drivers for Windows 7 (possibly because the laptop does not come with it pre-installed) however the Vista ones should work fine. As this is a reinstall, I suggest downloading and installing all the software, at least all of the ones under Drivers and Utilities to ensure that all of your notebook's features function properly.
Jul 05, 2011 | Acer Aspire 5102WLMi PC Notebook
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
Need windows 7 driver for alps touchpad on sony vgx-tp1. Since upgrading to windows 7 all drivers are working fine except for the touchpad on the keyboard. It's working for the most part, but the pointer...
http://drivers.synaptics.com/Synaptics_Driver_v10_1_8_Vista64.exe
try that one...
Found this site which referenced a newer Vista version of the TouchPad drivers.
http://windows7forums.com/windows-7-support/882-laptop-touchpad-not-working-windows-7-7000-a.html
I went to the Toshiba site and downloaded the newest version available for Vista:
http://eu.computers.toshiba-europe.com/innovation/download_driver_details.jsp?service=EU&selCategory=2&selFamily=4&selSeries=243&selProduct=821&selShortMod=null&language=13&selOS=all&selType=all&yearupload=&monthupload=&dayupload=&useDate=null&mode=allMachines&search=&action=search&macId=&country=all&selectedLanguage=13&type=all&page=1&ID=65296&OSID=26&driverLanguage=42
Mar 25, 2010 | Sony VAIO VGX-TP1 Living Room Notebook
Windows vista is froze at login mouse pionter stuck in middle of screen and key board doesnt work the cursor is blinking in the " enter password " spot tryed restore, repair and booting form disk
Hi..
Press fn+f9,it is the hot key for enabling or disabling the touchpad . it should enable the mouse.
all the best.
thanks for contacting fixya.com
Sep 22, 2009 | Computers & Internet
Touch pad
there should be a button on directly on top of pad. or you should be acble to disable it in device manger
also what model # is it.. incase that doesnt fix it and what ver of windows.
sorry there is like a 100's of presario compaq laptops
Aug 05, 2008 | Computers & Internet
Keyboard touchpad not working
y-ran 77 cordless keyboard...doesnt work with the l3600 multimedia desktop..it cannot recognize the said hardware...you need to use standard keyboard and manually install the driver for your y-ran77 cordless keyboard
Jan 13, 2008 | Computers & Internet
Toshiba Satellite® A205-S4597 PC Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
