Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Bottom 3/4 of photos are black
I have changed the lens and reset all of my camera settings and I'm still getting an image that the bottom 3/4 of the image is black. The upper quarter is visible and the line between the two areas is blurry, not defined.
Check out this website http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
I had the same problem. You can check to make for sure by removing your lens, and carefully lifting your mirror. Does the sub mirror underneath flatten against the other one when you lift it? That's probably what is in the way creating your 3/4 "black" picture. I just repaired mine as in this website, and the mirror moves great now! Of course, I'm used to taking apart laptops and such. If you have a warranty yet, contact Canon. It is a defective issue on there part.
Posted on Apr 02, 2009
  • 176 Answers
The sub-mirror under the main mirror, It\'s pin is damaged must be repaired by repair shop, Because you have to get to the inside of the mirror box to fix it.
Posted on Nov 19, 2012
The sub-mirror, which is a smaller mirror that acts as a 'flap' attached to the underneath of the main mirror, is failing to retract into the main mirror when the shutter is activated. The main mirror is lifting, as usual, but the sub-mirror is not retracting, so it partially blocks the light. If you reach in and pop up the sub-mirror, it will retract and the blocked images will go away. For the auto-focus to work, the sub mirror must extend again ( so that it is parallel to the sensor) whenever the mirror is down. If the sub mirror fails to extend, you will still be able to focus manually (there will be a ghost image in the viewfinder that is harmless and that you must just ignore). The above solutions mention replacing a pin that is associated with the sub-mirror movement. However, don't assume that the pin is broken necessarily. I probed around a bit, popped the mirror around a few times, and now the auto focus is working properly, as though nothing ever was wrong. We'll see how long this lasts, but my Rebel is destined for back-up camera status anyway.
Posted on Jul 05, 2009
    President:
  • 1,223 Answers
Have u tried firmware update here
http://web.canon.jp/imaging/eosdigital/E3kr_firmware-e.html
if not resolve then see this to clean the CMOS sensor
http://www.bobatkins.com/photography/tutorials/sensorclean.html
pls rate me FIXYA if i helped u i can help more if nothing work out above
Posted on Mar 21, 2009
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Photos have a black band at top and bottom. This has never occurred before on my Canon EOS Rebel XT. I use auto mode for all functions and have not changed any menu settings.
If you use the lens in wide and the f lash is not wide as same (if the lens is 18 wide and the f lash is 28 wide ) you will not get good photo so if use 18 mm wide lens then use 18 mm wide f lash and ( i have told about external flash )
Nov 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Sep 12, 2008 | Ricoh XR-10M 35mm SLR Camera
Sony DSC-P93 Image
Go to following Sony web link to see cloud like problem. If its like that, CCD Imager has problem n requires replacement.
http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCP92
May 30, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Image is half dark, despite lens changes
Hi there
The blacked out part is the bottom of the photo therefore the obstruction is at the top of the frame on the camera.
Try the camera on the BULB setting without a lens on & look into the throat of the camera. You should see what is not clearing the CCD completely.
It could be the sub-mirror which is a little mirror behind the main one for the AF function or a shutter blade not clearing enough.
I would go for the first one.
It could be because.....
1. the sub-mirror spring coming off or broken
2. the sub-mirror is glided by a post on the side of the mirrorbox & this could of come adrift.
Most repairers can deal with this fault. If the spring has come adrift you should be able to pop it back in place.
All this may not solve your problem but it will at least give you better idea of what you are dealing with.
Clive
May 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
A black line on the top and bottom
In your Recording Menu, check that the Disp. Overlay is turned Off. The lines are showing the portion of your image that will be cropped if you print a 4 x 6 photo (3:2 Guide).
Apr 06, 2008 | Canon PowerShot A560 Digital Camera
Bottom 2/3 of photo is black
It sounds like your autofocusing mirror is loose and obstructing the shutter.
Apr 03, 2008 | Canon Digital Rebel / EOS-300D Digital...
Black marks on pictures
It appears that you have dust on your sensor that is recording in the same place on each image. It is a common problem with digital cameras. If you are adept at cleaning the sensor yourself, it is a relatively easy chore. However, if you have any doubts about it, take it to a reputable camera dealer and let them do it.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
333 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
