Printer will not print what I want it to.
Printer work's but print's one thing every time I try to print. Cannot delet it. Not sure where it came from. Have tried many thing's. Never had this problem befor.
    Sergeant:
    Champion:
  • 245 Answers
Go to ur instruction booklet u got when u bought ur printer and look under trouble shooting.....it will tell u what to do.....
Posted on Mar 12, 2009
I have a lexmark x3400 printer and a windows 7 operating system. The current print job won't cancel and won't delete and I can't print anything else. I can't uninstall the device as it says the printer...
You will need to clear the print queue first before trying to send another print job. - Browse to Start -> cmd... and type in "NET STOP SPOOLER (this will stop the print spooler service) - Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> type cmd... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 24, 2011 | Lexmark X3470 All-In-One InkJet Printer
MY LEXMARKX5650 THERE IS A DOCUMENT STUCK IN MY QUEUE. IT SAYS DELETING BUT IT DOESNT DELETE I CANT PRINT MY OTHER DOCUMENTS I REALLY DONT WANT TO HAVE TO RESTART THE PC IHAVE A FILLED IN DOCUMENT THAT...
Disconnect the printer from the computer. Open the print queue, and be sure that the title bar says "printer offline". If it doesn't, select "use printer offline" from the file menu. Then try to delete the file multiple times if necessary to clear the queue. You may have to reboot the computer, but try this first. Also, you can try pressing cancel on the printer itself. If none of this works, disconnect the printer from power for 10 minutes, and try again. Good luck!!
Sep 29, 2010 | Lexmark X4650 InkJet Printer
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
Item won't cancel out of print queue. How do I
I have run in to this more times then I would care to count. Unfortunately, what worked one time did not necessarily work on a different computer and sometimes even on the same one. If, after several reboots, the problem still exists, disconnect the printer from the computer. Try again and reboot one more time and try.
If that fails, make sure you have the cd with the drivers or go to HP's website and make sure they are available.
Delete the printer! Reboot 2 times.
At this point, the queue should be gone. Reinstall the printer, reattaching it when asked.
Aug 03, 2009 | HP Deskjet D1341 InkJet Printer
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
My printer is keeps printing a deleted file!
try to delete the printer from printer & faxes.......
then reinstall both of the printer, make sure the port is right
May 18, 2009 | Nikon COOLPRINT Thermal Printer
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark X8350 can't delete from Print spool
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4270 All-in-One Multifunction...
Dell 942 all in one printer reinstalls itself
Not sure what your asking here. Please restate your problem and give all the details. The more the better so we may understand whats going on.
Sep 29, 2007 | Dell 942 All-In-One InkJet Printer
29 people viewed this question
jasbo
jasbo
