Question about Estate Dryers
Dryer Will Not Heat or Time Out
My Estate dryer quit heating and will not time out. Both problems started simultaneously. Heating element is good, getting 220v to the dryer, and replaced the timer. High limit thermostat, thermal cutoff, and thermostat check good. Any ideas?
  • Estate Master
  • 8,220 Answers
Did you remove the wires from each component before checking them? You got something open there.
Posted on Apr 23, 2013
Testimonial: "You are correct. Somehow I screwed up the check on the heating coil. I'm getting an open circuit, and last night put my eyes on the burned out section of the coil. Should have listened to everyone that said that the timer is rarely the problem. $85 mistake, but lesson learned. Anyone need a timer for an estate dryer? I have two :-)"
jumptrout51
  • 3361 Answers
SOURCE: NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Posted on Mar 10, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
hiltonjug
  • 612 Answers
SOURCE: can't control heat setting
Either your dryer vent is clogged, the blower wheel is striped out and not turning or the internal bias thermostat you bought is bad. These are the only things that can make the dryer over heat.
Please rate solution.
Posted on Sep 05, 2009
rickead1
  • 1998 Answers
SOURCE: Amana dryer not heating, replaced Thermal Cut off, High limit thermostat and Thermal Fuse, and new breakers in fuse panel
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
Posted on Dec 02, 2011
  • 2468 Answers
SOURCE: Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Posted on Feb 08, 2012
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
My estate dryer is not producing heat throughout the entire dry cycle.It does initially, but not all the time.Saw heating element glow and flame up shortly after , but will not stay on and dryer will run...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Estate TGDX640JQ Gas Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Sep 18, 2009 | Estate TEDX640JQ Electric Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
171 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
