I have dual opteron 246s' installed on my K8N-dl motherboard, but the second proc is not running, although I know both work... I am currently not running matching pairs of ECC in the dimms labeled A1- A2, b1 - B2, A3 - b3. IS this why? The machine boots using only one proc and a single installed dim of micron, 1 gig, pc3200, ecc registered mem. Do I need the A3 and B3 slots filled with matching pairs before the second proc will come on? The board works fine and I'm using it to post this. Thanks for any suggestions; please respond if you have a solution!
Show your appreciation by commenting on Asus K8N-dl - second processor present but not running...:
Solution #2
posted on Aug 06, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
I fgured out the main issue; that is, I was not using a 8 pin mobo power connector... I love the motherboard, paid $165 for it on ebay; when it retails around 300 - 400. I have never since seen another like it on ebay. A real find and a great mobo. I recommend the Asus K8N-DL, dual opteron Mobo to anyone running dual opteros.
Was this solution helpful? Show your Appreciation by rating it:
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
