TechnoTrend LCD TV-2712 on, no pic or sound.
Hi, my flat screen turn on, but nothing more. No pic, no sound.
Thank you for your advice.
5 Suggested Answers
  • 135 Answers
SOURCE: No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Posted on Jan 05, 2008
  • 44 Answers
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
ekcnoel
  • 998 Answers
SOURCE: philips lcd flat srceen
Good day Sir, the problem of your tv is the power supply if you remove the back cover of your tv, try to look for bulge up or leaky capacitor the bulge up is that the top is not perfectly flat and the leaky has a wet mark at the bottom of the capacitor this causes a low and unfiltered dc output, It will cause your main board to malfunction and the relay will keep on triggering until the capacitor holds enough power to turn on the relay. In order to resolve this problem you should replace the defective capacitor but be sure to remember the proper position because it has a polarity. Note before removing the back cover of your tv be sure to unplug it. Or if you are not handy in electronics I suggest that you should contact a technician to do it for you and save you from stress, Best regards.
Posted on Aug 06, 2011
gopakumarg43
  • 75311 Answers
SOURCE: SONY flat screen will turn on green light showing but no picture. TV turns off in 5 seconds. Advice???
Sounds like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Jan 10, 2017
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
Turn on no pic no sound. Tried power downno luck. Pulled all wires off and then reattached. Any advice is appreciated. This tv was bought in 2010.
If totally dead check out power supply first. If some life then suspect your main board which deals with both audio and video.
Nov 22, 2015 | Vizio E470VA 47 in. HD-Ready LCD TV
Tv turns on but has a blank screen and nothing happens.
If you think the back light is working then check out the main board since you have no pic and no sound.
Nov 12, 2015 | Televison & Video
No pic, just sound
Hi, you have not specified if your tv is still conventional tb that uses crt, or lcd
Jun 25, 2017 | Sanyo 42 in. LCD TV
When i turn my samsung 50, no pic or sound 3 lcd lights keep flas
Hi friend,,,
welcome to fixya
Commonly for plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Westinghouse 42 inch lcd flat screen tv
only get sound from my 42 lcd screen fro westinghouse, no display
Jul 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Jan 05, 2008 | Televison & Video
Viewsonic n4060w
HI I AM A TECH. I WORK FOR A COMPANY THAT REPAIRS LCD TV'S. IF YOU HAVE SOUND AND NO PIC YOU WILL NEED AN INVERTER BOARD THERE IS A WEB SITE CALLED SHOPJIMMY.COM THEY MAY HAVE IT
Dec 06, 2007 | ViewSonic NextVision N4060w 40 in. LCD...
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Televison & Video Logo
748 people viewed this question
Top Televison & Video Experts
