Question about Pool & Spa
Vita spa wiring diagram
How to wire the spa
  • 520 Answers
SOURCE: Need a wiring diagram
Apollo Spas Head Office printbutton.png con_address.png 1233 Andover Park East Tukwila WA USA 98188
con_tel.png 1-800-441-SPAS (7727) con_fax.png 206-575-2870
Posted on Feb 13, 2009
  • 80 Answers
SOURCE: need wire schematics -circuit panel box & heat element ARIES SPA
Did you check inside the cover of the control box. Most spa's have a schematic of their components there. Hope it is there.
Posted on Aug 19, 2009
SOURCE: Hot tub maintenance
DRAINING AND REFILLING BALBOA HOT TUB
Posted on Oct 24, 2009
john224
  • 1378 Answers
SOURCE: pool heater thermostat lights up but water do not
There should be a large, easy to read diagram under the cover once you remove it from the heater. Is the one under your missing or unreadable? Hayward doesn't publish one on their tech website or residential documents page so I have an email into our tech support contact asking for one in case yours is missing. If you find it under the cover please add a comment to that effect. FIXYA website has not been letting me post pictures lately so getting you the info may be a little difficult.
Posted on Dec 29, 2009
  • 8404 Answers
SOURCE: pentaire 011486 wiring diagram
My friend, my experience with the two speed pump in low speed is less than spectacular. There is so little filter action with the lower speed as to render the process useless. If you are trying to save $, better to run the pump a little longer then turn it off. My experience is in a commercial application. I run three such pumps in that system ... the additional expense of the two speed motors was a waste of capitol. In addition, as a commercial facility, we could not meet the required water turn over rate in our pools. Of course yours is a smaller body of water and you are probably not in a commercial facility. We get a LOT of cleaning (through filtration) at night, after the customers go home.
I suppose you could run your system with a intelematic switch ... I have not seen a 'three way' switch in this line ... having said that ... to my way of thinking ... you would wire directly through the selector switch on the back of the motor to each of two intelematic's; one on the high side and the other on the low side. I would allow at least 30 minutes between the two cycles to prevent impeller damage.
Thanks for your interest in FixYa.com
Posted on Aug 02, 2010
Wiring diagram AO Smith ST1102 pump motor
There is almost always the wiring diagram on the outside of every spa motor.
Bath Spa Parts Online
Jul 24, 2016 | AO Smith Pool & Spa
When you wire a vita spa do you need a service engineer or can you do it yourself
You can as long as you don't mind getting electrocuted if you get it wrong.
You have a dead short, so you will need to check every wire with a meter until you find the one that is earthed. First place to check would be your pump and then the lights, and the heater and the control panel.
Another way to check would be to disconnect those items and then turn on your breaker. When you find the component that has been disconnected and the breaker doesn't trip will indicate the item that is causing it, or the wiring to that item.
My advice is to get it fixed and serviced professionally. Also they may well have seen this problem before.
Apr 16, 2016 | Pool & Spa
I have a vita duet spa. It has a pb error and the jets or the lights will not turn on. Any suggestions?
Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
Nov 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Wiring diagram for BlueRidge Spa
The wiring diagram for each spa is located on the inside panel of the control box.
Remove the side panel of your spa where the control box is located which is usually on the same side where the topside button is.
Once you remove the side panel you will see the control box.
Remove the front cover and on the inside of this cover is where the electrical diagram for all the wiring is found.
Rod
US Parts Center
Nov 02, 2013 | Pool & Spa
I can't get the high speed motor on. It operates in low speed. Is there a wire diagram?
All pool and spa motors are required to have the wiring diagram on the side of the motor.
Oct 19, 2010 | Franklin Pool & Spa
Need manual for a vita bijou hot tub
Vita Spa is now out of business, so contacting the factory isn't a option. You can try googling for an online manual download. They usually cost between $10 and $15.
Jun 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Pool & Spa Logo
361 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
