Question about Sanyo DS27800 27" TV
3-digit code for remote
Need original 3-digit code for Sanyo TV. Sanyo remote # FXVS
5 Suggested Answers
dauphine
  • 207 Answers
SOURCE: code for tv remote
Try these codes. One of them should work:
017
021
039
056
057
058
Posted on Apr 10, 2008
SOURCE: Universal remote codes
I need some codes for my sanyo T.V.
Posted on Oct 12, 2008
  • 41 Answers
SOURCE: tv code search
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
Posted on Aug 04, 2009
  • 5 Answers
SOURCE: I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Posted on Aug 23, 2010
What remote codes do we need to connect remote to Sanyo TV model 3264B 2008.
Mary, Universal remote codes for Sanyo TV model 3264B Check the attached links,instruction and guides containing 3 and/or 4 digit codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Apr 26, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
I Need to Find coad to program Remolt For Sanyo TV/Dp37647
The universal code for most is 049 for a Sanyo TV. With your universal remote you press the code search key until it illuminates and then you press and release the TV key. Next enter the three digit code (3 digit remote code page) and the indicator light turns off.
If you enter in the wrong code the light will flash rapidly. Aim the remote at your tv and press the on/off key. If your tv turns off then you have found the right code!
Try these codes for your Sanyo TV also: 054, 069, 023, 025. If those do not work then also try: 004, 013, 049, 108, 110, 180, 209
Read more: http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs/#ixzz3w1wdIQ6I
Dec 29, 2015 | Sanyo Televison & Video
NEED A CODE FOR A SANYO CRT TV WITH A SANYO REMOTE
0854,0347,0223,0548,0532. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Panasonic Televison & Video
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
I need the 3 digit code to program my remote to control the TV
Is the remote original to the TV? If this is a universal or cable/satellite service remote, follow programming instructions for that remote. Most have a auto programming feature which will locate that code for you by following that method of programming codes.
This code will have to be obtained from the manufacturer of the remote that you want to program. Refer to the Remote Owners Manual
Mar 22, 2012 | Sanyo DP19649 LCD TV
Need a code for a remotec uni remote it dosent have sanyo codes on it
Try the second link first but here is a link to some codes for sanyo TV's but I think they are for older models because they are 3 digits.I'm pretty sure the flat screens have 4 digits so hang on.
http://en.kioskea.net/faq/281-universal-remote-codes
Here are some 4 digit codes.The remote which the links say they are for may not necessarily be your remote,but I'm 99% sure that no matter what brand,the numbers are basically the same.If these do not work,just reply to this post and I will get an auto email for it.Also,you could call Sanyo and get an original one for your TV but they are more expensive but they also have better control options.
http://wiki.answers.com/Q/What_are_the_sanyo_tv_remote_codes_for_the_rca_crk74b1_universal_remote
Good luck! Greg
Aug 19, 2010 | Sanyo Televison & Video
Tv codes for sanyo tv for a phillups magnavox pm35 remote
SANYO TV 3 digit codes; 328 425 426 428.
SANYO TV 4 digit codes. 0506 0311 0612 0002 0428 0802 0412 0619
Jun 22, 2008 | Philips PM3S Remote Control
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Sanyo DS27800 27" TV Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
