Question about Vacuums
Power head for H20 Vac Turbo Water Filtration System Vacuum Cleaner
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
LizDahl
  • 75 Answers
SOURCE: aqua vac vacuum cleaner
yes you do need water... but water vacs dont clean as well as a good old suction driven machine.... aerus has several great models available
Posted on Feb 27, 2008
SOURCE: The bissell proheat turbo carpet
Bissell cleaner will not **** up water???
Posted on Sep 14, 2008
  • 1214 Answers
SOURCE: central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Posted on Jan 23, 2009
  • 52 Answers
SOURCE: how to disassemble power head on kenmore vacuum
uselly there is 2 scews and a couple of lock tabs
Posted on Mar 03, 2010
Water smells like sewage
The drain is connected to the sewage system, so the smell could come from there, install a trap valve
Mar 29, 2013 | H2O Audio H20 Vac Turbo Water Filtration...
My h20 vac is smelling like its burned out it aint sucking up and just want to know how do i fix the problem when it turns on
Sounds like the beater brush has frozen up and the belt is being burned by the motor.
Follow the instructions to change the beater belt and when you have the brush removed, clean it as best you can. At each end of the brush, add some WD40 to help the brush spin easier in the end holders attached to the brush. Reassemble and be sure the new belt is properly installed so the brush moves in the correct direction.
If you find this solution to be helpful, I would appreciate and appropriate Thumbs Up rating from you.
Be well, Paul
Oct 06, 2010 | H2O Audio H20 Vac Turbo Water Filtration...
Bissell Proheat Turbo. 1 year old. It will not **** up water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
p
Jul 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Pro hEat will not **** up water from carpet
check the vac motor hose could be clogged? does the vacuum motor turn on? check the vac motor on switch for power using an ohms meter.could have a bad vacuum motor or micro switch.
Jan 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I am interested in bying Rainbow cleaner, i am not shure about my electical supply. I live in Europe,and wee use 200v insted of 110v so I need a transformer. Could you specify The power in watts and ampers...
If I may comment, as an allergy sufferer and service tech,and former Vac Store Owner, etc, a Rainbow, IMHO is a waste of time and money.
A Rainbow or REXAIR works on the basis that it filters dirt through a water tank,with a `centrifugal separator` when in fact as it runs, it actually humidifies with dirty water, releasing nasty stuff back into the air.
Although the motor is good quality the humidity often causes rust damage as the vac ages leading to VERY expensive repairs with proprietary parts.
Test the filtration theory for yourself, do two things, pour a packet of orange drink crystals into the bucket with water and run the vac , you will smell the orange because it is being mixed with moisture and released into the air. Dirt will do the same. I have done this in front of a Rainbow Salesman in my girlfriend`s home, he was speechless...
Also pull the exhaust plug cap from the back of a rainbow after it has been used and wipe the dust from the inside of the cap. The dust should not be there if in fact the vac is all it is puported to be, but you will find it.
There are some excellent vacs in Europe, SEBO and Nilfisk are two with exceptional filtration. and are both very tidy to handle when emptying. They will also provide excellent tools with good cleaning results. Miele also makes several very good units, which should provide years of service.
For my money, it would be SEBO....Just remember, when it rains , the air smells great , but the street is still not clean, water and dirt dont mix
Sep 20, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My carpet cleaner doesnt **** up the water and cleaner it is a bissell turbo proheat 2x
heatman101
ydtyd
Sep 20, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water will not spray out and pick up
My steam vac wont spray out the cleaning products.
Feb 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
