Question about HP Office Equipment & Supplies
Checking ink levels on hp deskjet 2052a printer
vegakitten20
  • 685 Answers
SOURCE: My HP Deskjet F370 All-in-One do not shows ink level
try reinstalling the printer.
Posted on Nov 19, 2008
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
Posted on Feb 28, 2009
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    aicaxz
    • 511 Answers
    SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
    Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
    Posted on May 31, 2009
    Hi. I cannot find where to check the ink level in my deskjet 3500. Can you help me? - thanks.
    When you installed the printer from the HP-supplied CD-ROM, you installed the HP Printing Assistant. Use its "maintenance" tab to check ink-cartridge levels.
    Or, open Control Panel, and open Printers, and right-mouse-click the printer, and choose Properties, and you should be able to use a utility program to check the levels.
    Jun 26, 2011 | HP DeskJet 3550 InkJet Printer
    How do I check ink levels on my HP Deskjet 4160 printer?
    Go to printers in control panel> Right click on the printer and go to printer properties> Printer Preferences and click on color> Then click on the Estimated ink level on the top.
    Jan 04, 2011 | HP Deskjet D4160 InkJet Photo Printer
    There is no icon on the taskbar, and I cannot figure out how to check the ink level.
    The HP Toolbox can be used to check ink Levels
    1. Right-click the taskbar printer icon .
    2. Click Open HP Deskjet 5550 Series Toolbox .
    3. Click the Estimated Ink Level tab.
    4. Check ink levels (estimate only, actual ink levels may vary)
    Sep 23, 2010 | HP DeskJet 5550 InkJet Printer
    How do you check the ink levels of the cartridges on a hp deskjet 940c
    If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
    Thanks
    Shereena.
    Apr 22, 2010 | HP DeskJet 940c InkJet Printer
    How do I check ink levels on my HP deskjet D4160 printer?
    Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
    http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
    View estimated ink levels
    Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
    1. Open the printer Toolbox.
    2. Click the Estimated Ink Level tab.
    Note If the print cartridges were used before being installed in the printer, the
    estimated ink levels will not appear on the Estimated Ink Level tab.
    The Estimated Ink Level tab also contains print cartridge ordering information. To view
    this information, click the Print Cartridge Information button.
    Thanks and good luck.......
    Pls rate me
    Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
    How do I check the ink level on my HP Deskjet 460
    Click Start
    Click Control Panel
    Click Printers
    Click with 2nd (right?) mouse-button on the HP printer.
    Click Properties.
    Click either Tools or Advanced.
    Click to "show ink levels".
    Oct 09, 2009 | HP Deskjet 460c InkJet Printer
    I want to check ink levels
    To check the ink levels ofyour printer click on the start button of te computer and then click on control panel now go to printers and faxes open it and look for the name of your printer right click on the icon and go to properties now click on printing preferences and then go to the features tab in the features tab look for the printer service tab now go to the estimated ink level tab and see the ink level
    Aug 28, 2009 | HP Deskjet 6980 InkJet Photo Printer
    Can't find ink levels for my HP Deskjet 5940
    The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
    Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
    63 people viewed this question
    Seeker5211
    Seeker5211
