Question about Dream Maker Spas Big-ez Sandstone Hot Tub - Factory Second
How do I know if tub is heating properly - Dream Maker Spas Big-ez Sandstone Hot Tub - Factory Second
    Scholar:
    New Friend:
  • 45 Answers
Pools are an oft-coveted backyard feature because they not only provide a place for swimming, playing and lounging, but they can also give the area the look of an exotic tropical escape. Bonus features like hot tubs and waterfalls expand the recreation possibilities of a pool. Whether you are designing a pool for your dream home or for a luxury hotel, take style preferences and practical considerations into account to ensure the pool, the waterfalls and the hot tub work smoothly.
Read more: http://www.aurorapoolsandspas.com/ Aurora Pools and Spas Lexington KY
Posted on Jan 08, 2014
Tip
How to Replace the Dishwasher Heating Element
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
on Apr 19, 2010 | Dishwashers
Tip
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
http://www.fixya.com/support/r4319937-dishwasher_maintenance
My Balboa 300F hot tub will not heat up. I am not able to get it out of economy mode. What can I do?
First, balboa does not manufacture hot tubs! They make control systems for hot tubs. If you are no longer able to switch between modes, then your topside control panel buttons are dead or falling. But... Even if you are still in economy mode, spa should still heat up. Once a demand for heat is recognized, you have a "Heat Call" and heater should come on. Is the "heat on" light, illuminated? If so, water should be heating, if not heater element may be bad? A multi meter would be good here: is there proper voltage at terminals on circuit board to heater? If so, bad element! If no voltage, then heater is not necessarily bad, probably just fine, I would then look at sensors? Good luck
Feb 23, 2015 | Pool & Spa
I have a HS200VS heater in my hot tub. We bought it used. It always had an error code and would stop working in Standard mode, but worked fine in econo mode. Now we have no heat, but still have power. Need...
Not enough to go on...
what error code did you get?
How do you know you have power? Is it proper amount of power?
Did you use a multimeter to test this?
Just lights on the control box, is insufficient way to tell for proper power.
Jul 30, 2013 | Balboa Instruments Garden
Electric dryer heats properly and is still drying properly but makes a thumping noise while working.
More than likely this is a tub roller. Looks like a small tire and wheel. that the tub rolls on.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | KitchenAid Dryers
Dryer does not heat up properly. heats well at times. other times it doesn't. sounds like the heating element is turning on and off and not staying on long enough to heat the tub up.
Most likely cause is lint accumulation around the control thermostats or the control thermostat defective. Access to the control thermostats requires lifting the top. Lint accumulation is the most likely culprit, not allowing the thermostat to properly sense air temperature in the dryer, trapping heat so the dryer 'thinks' the air is warmer than it really is.
Hope this helps. Good Luck.
Sep 11, 2009 | Estate Dryers
No heat
have you checked the heating elements? you say the tub turns, is there any air coming into the tub and if so is it cold? if it is then you may want to get the heating elements checked.
Feb 09, 2009 | Kenmore 63942 Dryer
Dryer does not heat
I don't know this machine, but I know Malber single tub machines well and this problem in the Malber machines is alost always due to a worn out heating element, similar to the heating element in an electric oven or electric stovetop range. If you have had the machine for at least several years, and noticed that the dryer was becoming less effective, then I bet it's the heating element which needs to be replaced.
Aug 01, 2008 | Siemens WK61420GB Front Load Washer /...
Dream Maker Spas Big-ez Sandstone Hot Tub - Factory Second Logo
125 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
