My screen is displaying in quad (4 identical images)
This screen is displaying in 4 identical images. Dell Inspiron B130
  • Shadow1989 May 11, 2010
    Are you talking about the background image or 4 seperate screens?
Backlight display on my inspiron b130 laptop. All images are barely visable. Laptop powers up as normal but images are very faint
If your notebook appears to boot up and the hard disk LED flashes, you could have a back light problem which can be caused by a faulty inverter or a faulty CCFL lamp. Please click on this link to determine the fault and fix :-
Nov 20, 2010 | Dell Inspiron B120 B130 1300 / Latitude...
What do I need to connect my dell Inspiron B130 to my panasonic viera tv?
Hi. Try buying a VGA-to-HDMI cable/adapter and connect the VGA to the side of your Dell B130 and the HDMI end to the back of your Viera. Press Fn+F8 on your laptop and you should be able to view the display on your TV.
Hope it helps... ^_^
May 19, 2010 | Dell Inspiron B130 Notebook
Generally, a cable connection or cable issue. not all the color signals are making it to the projector. Try reseating the cable connections on both ends. If no changes, then try another vga cable
Mar 18, 2010 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 screen screen glitch
This could be a screen cable problem but it is normally a faulty screen even though it may look like a loose connection. Get a technician to check it for you.
All the best.
Jan 19, 2010 | Dell Inspiron B130 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Display goes haywire...
The easiest solution is remove the hinge cover and check if the LCD cable got cut.
follow the following instructions to replace display assembly
You can also run diagnostics.. power on and press F12 on dell logo slowly 5 times
Select diagnostics and follow on screen instructions.If the LCD fails its time to replace the same.
Apr 06, 2008 | Dell Inspiron B130 Notebook
Dell lcd display
if it is just half of the screen and the rest is black- you need a new screen. If it is half the screen all squished together (you can see the whole desktop) you need to reload the video driver
Nov 22, 2007 | Dell Inspiron B130 Notebook
Mutiple screens after startup
From your description it sounds like you've got an image set as your desktop background and it set to "tile" mode. If this is the case you can change it as follows: -Click on Start, settings, control panel -Double left click on Display. -Click on the Desktop tab -If you want to remove the background image just highlight None from the list of backgrounds. If you just want to display one, small image click on pull down arrow to the left of the Position field (bottom right hand section) and select Center. Use Stretch to make the picture fill the entire field. If this solves your issue please don't forget to rate the posting, otherwise give us some additional details as to the exact nature of your issue.
Jan 29, 2007 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
