MSH-A30VD-p1 - Heating & Cooling
Replacement remote for Mitsubushi aircon MSH-24TV, how do we get them talking?
If you wish to buy a genuine remote control, you have to contact the authorized service centre for Mitsubishi. If you wan to buy a universal remote control, you should first check, which brand remote control have setup codes to Mitsubishi brand TVs. If you wish to get this detail, try the links given here. It has setup code list, and setup procedure to many popular brand remote controls. Check and find out which brand remote control have the codes to Mitsubishi, and buy that one according to availability.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 24, 2013 | Televison & Video
What memory stick to i need for dcr-trv340e?
Go to http://www.sony-asia.com/support/resources/en_AP/html/Compatibility/MemoryStick/handycam.htm and note the first two options: MSH-128S2 used directly, and the MSH-M128N used via MSAC-M2 adapter.
Feb 18, 2012 | Sony Handycam DCR-TRV340E Digital...
What memory card do i need for my sj30 and where can i purchase it?
You need a Sony Memory Stick
Here's one on Amazon: http://www.amazon.com/Sony-MSH-M128A-Memory-Retail-Package/dp/B0000D8HLL/ref=pd_sim_e_1
Mar 05, 2011 | Sony CLIE PEG-SJ30 Handheld
My MSH 024 Air Conditioner keeps tripping off at the mains switch
FIRST TRY TO CHECK THE CIRCUIT BREAK THAT IS CONNECT TO THAT AIR CONDITION, USUALLY IS A 30 AMPS OR 40 AMPS CAPACITY, MAYBE IS BELOW THE AIR CONDITION CAPACITY AND OVERHEAT THE BREAK, OTHER WISE UR SHOULD CALL A TECHNICIAN TO CHECK THE COMPRESSOR AND THE COIL OF THE CONTACTOR
Mar 09, 2009 | Comfort-Aire MSH-024 Air Conditioner
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
Just purchased a canon A590. on page 84 of user guide, continuous shooting is described. I'm somewhat familiar with SD cards, but Canon implies that I have to use their MSH type SD card to use the...
I don't own an A590 but I've been handling cameras since the Kodak Instamatic days, so I'll try to help you. I checked out the Canon website for the A590. and they don't specifically state the MSH type SD card. The camera can do 1.4 fps or frames per second of continous shooting. But it also identifies a 20 and 30fps which refers to the movie mode. If the manual states a MSH type Sd card, it usually means that the card may be of a faster recording speed to take continous shots. But I think what you might mean continous shots could be the 3 or 5 second burst on the Digital SLR cameras. These modes are usually for sports and very good for Formular 1 racing pictures. The specs of your camera does not have a sports mode or any continous burst. So you will be stuck in the 1.4fps levels. Let me know if this helps.
Nov 12, 2008 | Canon Cameras
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Memory stick duo problem
Yes it should work. Make sure that you are buying a DUO and not a DUO PRO (cause the DUO PRO won't work).
Dec 16, 2007 | Sony Ericsson P800 Cellular Phone
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
