Sanyo dp46849 Only half of the screen comes on but the other half is black but you can still tell it works because it still lights up black.
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
It sounds that there is some loose contact with the connection wires between its LCD control panel circuit board [T'Con] and LCD panel. Re-seat them once and check. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. Screenshots of faulty screens and reasons are given in detail.
Posted on Apr 22, 2013
  • 63 Answers
SOURCE: my sanyo dp46849 screen is discolored with red and
common issue with this model. if im correct not only is it red but it also has a ghosting affect this is caused by bad controller boards connected to the tv screen itself it is not any easy fix the only real option is to replace the whole panel which can cost between 200 to 1500.
Posted on Feb 22, 2011
budmrtn
  • 11361 Answers
SOURCE: DP46849 has black screen with power light on.
It may be in safety shut down mode due to shorted circuits or power supply failure due to such thing as bad DC filter caps. You will need to do in-depth troubleshooting.
See www.shopjimmy.com if he has the picture of the boards.
Please read my guides also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 23, 2011
caroldon
  • 17130 Answers
SOURCE: I have a 46" Sanyo
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on Jul 08, 2011
ekcnoel
  • 998 Answers
SOURCE: sanyo dp46849 when first turned
The problem of your unit is the CCFL - cold cathode fluorescent light. if the both ends of the ccfl is already have a dark spot it must be replace or sometimes the holder of the ccfl is only loosed. Or try to consult a technician for sure, to do some actual test to your unit if you are not familiar in electronic parts and to lessen the stress. Good day and best regards.
Posted on Aug 09, 2011
  • 29 Answers
SOURCE: one side of the tv has a black shadow and then
Disassemble TV, clean all boards from dust, unplug/replug all connectors,
most are really small, be careful, try TV again. Out Same Model TV started off the same, left bottom of screen/shadow when TV was on for awhile, since then has got worst, like 2 shadow boxes showed up, now upon startup, TV is screen is covered w/vertical lines, shut off the TV once or twice and works fine until next startup. If the above does not fix TV, look at the top of TV from Back Panel Off, Top-Center is a board called T-Con board, replace it. All the info for this board replacement is on the Bar-Code Laabel and Board itself, ie; T370HW02 VC CNTRL BD, 37T04-COG, FX-5546T03C22 (orC21)-964-0000NMP-00629-03 this board is Mgr By AU Optronics. GoTo For Parts/Pricing, they have 180 warranty on parts, aprox $45.00 for T-Con . http://www.shopjimmy.com/auo-55-46t03-c22-t-con-board.htm
Posted on Dec 11, 2011
How do i fix my tv? it has sound but no picture it is totally black.
Do the flashlight test on the screen. If it passes the test then the issue lies with the inverter board that powers the backlights.
Mar 29, 2016 | Sanyo DP46849 46 in. HDTV
Half the screen is blacking out.
Does your TV support "picture-in-picture" (two independent windows, and a "split" screen) ? Reconfigure it to "maximize" one of the two windows.
Jun 16, 2015 | Sanyo DP46849 46 in. HDTV
Sanyo model number DP46849 half the screen is black
This is a problem with the ribbon cables taking the signal to the various parts of the panel. The cable is bonded at the factory. That bonding has failed in one part of the screen.
Unfortunately, the bonding can't be fixed with just a blob of glue. If the ribbon cable is removed then it will never work again. The connections are too fine.
The answer is to use some neoprene tubing to put light pressure on the connection. This is done by opening the case and inserting the neoprene like a round wedge.
Sep 08, 2014 | Televison & Video
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
My sanyo flat screen is fading on the right side but after awhile in clears up
Most of these sets use two boards that drive (each) one half of the screen---a problem can be a bad board or cable or plug connections and can escalate as time goes on.
Jun 16, 2012 | Sanyo DP46849 46 in. HDTV
I have a 46" Sanyo
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
DP42647 On half of our 47 inch screen it is black and distorted when we first turn the TV on but after 30 or 40 minutes it finally just lights up and is fine.
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish board that call the T-CON board for the replacement.This board sit in the middle at the bottom of the LCD screen panel.This T-CON board only job are to decodering picture pixels dots only before it show up to the LCD screen panel.
Jun 10, 2011 | Sanyo DP46849 46 in. HDTV
My sanyo dp46849 screen is discolored with red and black, any wisdom is appreciated
Feb 22, 2011 | Sanyo DP46849 46 in. HDTV
My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Feb 28, 2010 | Sanyo DP46849 46 in. HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
