Question about Sony VAIO VGN-FS550 Notebook
Keyboard keys malfunction
My sony vaio vgn fs550 keyboard keys r, y, u, and ctrl suddenly wont work...any ideas or solution to this...would be greatly appreciated
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
Feb 04, 2018 | Sony VAIO VGN-NW150J/S Notebook
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
Some keys on Sony Vaio VGN FS830w stopped working
Hi:
Most of the time it is a keyboard failure. You can troubleshoot this by plugging in an external keyboard and seeing how that works, but most of the time it is your keyboard. They are not expensive on ebay, maybe $15 + shipping, and not hard to change
Larry
Oct 24, 2009 | Sony VAIO VGN-FS830/W Notebook
How to replace keyboard on sony vaio VGN FW230J
This kind of replacement needs to be performed by qualified person. Better take it to the service.
Jun 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
Space bar types a space and a '/' hash /mark
you should go to control panel then click on keyboard setting and reset your key board or put on screen keyboard
Apr 13, 2009 | Sony VAIO VGN-FS550 Notebook
Sony vaio keyboard fault
Hello, my name is Chris. Easy solution. Buy a new key board. Thats all you can do in this situation. There not worth trying to fix. A key board will cost about 10.00.
Mar 04, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Reformatting a sony VGN-FS550 Computer
download the drivers at sony e support website...insert a bootable operating system..this will format your laptop and erase all files..once the operating system is installed, install the drivers...and your son could use the laptop without him seeing your files
Jan 26, 2009 | Sony VAIO VGN-FS550 Notebook
The dvd drive of vaio FS550 does not read or write.
i think ur cd drive lens needs to be cleaned by a lens cleaner...
Jan 12, 2009 | Sony VAIO VGN-FS550 Notebook
How do I use the "AltCar" on my labtop?
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Dec 19, 2008 | Sony VAIO VGN-FS640W Notebook
Sony VAIO VGN-FS550 Notebook Logo
142 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
