My TECHWOOD tv will just start flashing between the blue and orange lights in the middle of the night while on standby? Any ideas?
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Check its T'Con board's connection cables. If there is some loose contact to these connectors with sockets, this type of fault can occur. Check it first. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help.
Posted on Apr 22, 2013
5 Suggested Answers
brandonm99
SOURCE: Hi, I have a Hitachi
mines does that to it means that its updating
Posted on Feb 18, 2012
SOURCE: TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
Posted on May 15, 2008
  • 135 Answers
SOURCE: TV Problems!
This is usually the high voltage on the inverter, balancer or backlight arcing to the chassis or at the connections. One quick fix was to look for a burn spot under the inverter(s). If that's the case, insulate the chassis at the point of the spot with a few layers of electrical tape 600v dialectric strength or better and carefully clip the leads just above the solder joint on the inverter board to widen the arc gap. If the white pink wire connectors arc too long they will charr requiring replacement. Cost varies depending on the problem.
Posted on Nov 10, 2008
  • 4090 Answers
SOURCE: blue light flashing
Possibly the power board or the sustain board has died.
Power board failure does not stop the blue light from working as this is an LED on voltage side of power transformer. The set fails because it has detected a voltage difference in one o0f the other boards that controls the initial starup and convergence. Some transistors and capacitors are also possibly involved. Not a dIY unless you are skilled. Parts $300 labour ?
but about $400
If you are a DIY get a kit from this site, complete with step by step instructions This is an LCD rear projection set.The yellow blob may be from the drivers to the LCD display, dirt or object on the projection mechanism, stain on the mirrors or lamp; bad projection lamp - among others.If you are handy, get inside the set and see if you can observe any of the items mentioned above.
Ploease rate my help++++ Thanks for using FIXYA
Posted on Feb 26, 2010
Finlux 32 fld850u
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 25, 2014 | Televison & Video
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
Dec 17, 2012 | Televison & Video
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
Hi when i go to turn my TECHWOOD lcd tv on the blue standby and the orange on light just continually to flash on and off..have you any suggestions to why this is happening..many thanks
hi;
if there's standby light and wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician.
thanks ,, hope this help.........
Sep 05, 2011 | Televison & Video
Last night my tv shut off. the whit/blue light in the middle bottom of the tv is flashing 8 times then stops and repeats. i have removed it from the surge protector and tried it in a wall outlet. i have...
My tv is on the fritz too.. Its basically doing the same thing. Im guessing it has the same capacitor problems all those others are having. Mines only 3 years old, paying 1500 for a now $700 tv.. Ive yet to find a price to fix it but nothings going to satisfy me. And all the talk sounds like samsung wont do a thing to help. Ready to invest in a good old am radio and boycott the tv industry. Sorry this wont help but I felt like venting.
Jan 27, 2011 | Samsung LN40A550 LCD TV
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
Electro Med Services...
