Question about Solaire Stainless Steel BBQ Tray for Gas Grills
Beaumark purchased a stainless steel beaumark bbq approx. 4 years ago. This year, it won't turn on, unless we do it manually and the flame stays on low all the time, then poofs and goes out. Cam u please advise
Some burners don't work
this is a gas fireplace & everything is on low flame high flame it just won't stay lit
Jul 01, 2012 | Brinkmann Charmglow Stainless Steel LP...
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
What is so cool abat them
Having been in the grill business for a number of years, I can truly say, "There's not much that sets Lynx apart from any other high end stainless steel gas grill."
1. They use cast brass burners instead of cast stainless steel (no big difference in longevity there).
2. They use full ceramic briquets as a flame tamer As do several BBQ's Galore Gas Grills.
3 The grill is made entirely of 304 Stainless Steel, with some areas polished to a mirror finish. So does the Fire Magic grills.
4. They have as good a warranty as most of the other high end grills.
Is it a better grill overall, than those you'll find at your local home center? Definitely, Yes!
Is it worth over $2000.00? That depends on how much grilling and entertaining you do and how well you take care of the grill. All of them (High End or Low End) require routine cleaning and maintenance. Don't do it and you'll have problems. Also a good quality quilt lined cover is essential Not a $19.99 vinyl special.
Hope this helped answer you question.
Jun 07, 2011 | Lynx LBQ27FRE (NG)
How do you remove stone sealer from a stainless steel BBQ grill?
You may want to try a couple of things.
Muratic acid
or
paint thinner
Don't mix the two.
Either one may stain your metal though
Jun 26, 2010 | Cal Flame BBQ07899P Stainless Steel...
Low flame
Either ;
1 your valve is not opening on your tank,
2 your regulator is bad on your tank, or
3 your out of gas.
Unless your second burner is going fine then you have :
4 a bad burner valve control not opening or
5 Some cobwebs inside the burner blocking the gas flow.
If this helps you please rate me with as high a mark as you can. Thanks for using Fix ya and Good Luck
Mar 26, 2009 | Ducane 30400040 Stainless Steel Grill
Solaire Stainless Steel BBQ Tray for Gas Grills Logo
64 people viewed this question
Top Solaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Solaire Grilling Expert? Answer questions, earn points and help others
