Question about Water Heaters
There is no power going to the pump in my boiler
My boiler has been checked by a corgi registered plumber, and he has diagnosed that there is no power gong to the pump, any ideas????
  • Water Heaters Master
  • 3,284 Answers
Power to the pump goes via the room stat in turn from the programmer check these out first
Posted on Apr 24, 2013
2 Suggested Answers
  • 152 Answers
SOURCE: pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Posted on Feb 23, 2009
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Brand new valiant condensing boiler installed will not work
Valliant boilers have software that can be used to diagnose the unit. The software can be purchased at the plumbing supply house that the boiler was purchased from. You can also get tech. service by email as well. It sound like there is an issue with the electrical controls with it. Or the controls were wired wrong.
Technical enquiries 01634 292392 or technical@vaillant.co.uk
Apr 01, 2009 | Water Heaters
Pilot light on boiler
Good luck...
Feb 22, 2009 | Water Heaters
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
the thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Jan 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Open vent central heating
yes it is possible toupgrade the system to a sealed one using a system boiler as you mentioned. the thing to bear in mind is to upgrade the radiator valves to pressure rated ones 10bar.
The probable cause of the over heating is down to the system being sludged up/cold feed blocked, or possible pump circulating problem?
I would recommend the installation of a magna clean filter to help keep the new boiler clear from system debris.I would definately power flush the system, if the system is a twin two port valve system then a automatic bypass should be fitted, all of this done by a corgi registered gas engineer
Kindly
Richie
Dec 18, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
How to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Dec 17, 2008 | Water Heaters
Gas boiler
hi sounds as though the system is sludged up & needs power flushing.the reason is that the water cannot circulate so over heats & pumps into the header tank.
expect to pay approx 350 400 pounds to have it properly cleansed, it will restore the system efficiency.
The other area worth considering is that it could be a faulty pump os that when th eboiler fires it cannot circulate so in turn expands & vents into the tank.
My advise is to arrange for a corgi engineer to sort it out for you.
Kindly
Richie
Dec 17, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Thorn m gas boiler
Hi alex1000
I'm Harvey the Master Plumber.
Water pumps should always be horizontal or up. Never down. That would allow a place for any dabrie to acumulate and shorten the life of the pump.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Water Heaters
Water Heaters Logo
55 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
