Need to set time and date - Office Equipment & Supplies
  • kakima Apr 23, 2013
    Sorry, FixYa seems to be having problems inserting links. It'shttp://www.google.com/url?sa=t&rct=j&q=m...
    An alternate link ishttp://www.brother-usa.com/ModelDocument...
  • 20 Answers
Press Menu and then press zero to enter the "machine setup" menu, then scroll through the prompts.
Posted on Oct 17, 2013
  • Brian Mathews Oct 17, 2013
    Press Menu and then press zero to enter the "machine setup" menu. Scroll down through the prompts to locate the date & time change feature.
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
Mar 01, 2013 | Panasonic Cameras
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
How to set time and date on a sony psp
go to settings then go to date and time settings from that you can change all the settings of the time and date.just send me a message for more solutions.
Nov 24, 2012 | Sony PSP (Piano Black)
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
How to set time on your camera so that when you print your photo's, it shows the date
The date/time setting process may be slightly different on different camera. Which camera do you have ? Nevertheless, you first need to set the date/time on your camera. And when you print, say using PictBridge, you need to set the DPOF date setting at WITH DATE. And you need to use a printer that supports date printing.
Feb 18, 2011 | DSC Cameras
Cannot set date & time on Panafax UF-895
To set the date and time, do the following:
  1. Press function 7
  2. Press 1
  3. Press SET
  4. Enter date and time using 2 digits for month (sept 09)
  5. Enter 2 digits for Date
  6. Enter 4 digits for year
  7. Enter 4 digits for time (military time ex: 3pm 1500)
  8. Press SET
  9. Press STOP
The date and time are now set. Best of luck.
Greg
Aug 24, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
Mar 25, 2009 | Motorola Cell Phones
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
k24674
jasbo
jasbo
