Question about HP Pavilion dv9000z Notebook
Humming noise on HP Pavilion dv9000
I just purchased this labtop last week. It is great except for the humming that is coming from the keyboard area. Any suggestions? Should I return and get a new one? I don't think I can live with the buzzing/humming for long. Thanks
  • 4 more comments
  • Georgia Ellis Aug 04, 2007
    It is not the sound card because I have tried to mute and it stays humming. It is louder on the bottom of the computer when I lift it up to hear underneath it. It is not a grinding noise, just a constant buzz that is located in the center of the key board. Thanks for your help, it is helpful.
    Good to know that I am not alone, but I am not comforted by the fact that it seems to be a built-in problem- that blows. Have you found anything that would fix it or make it better?? Thanks
  • wpmoss Nov 13, 2007
    I have had this dv9000 since August 2007 and the other day the fan began emitting an annoying humming noise. The fan shouldn't even run all the time should it? Well it appears to be and it constantly makes that noise. Any help?
  • wass79 Feb 11, 2008
    I bought a dv pavillion 9705 ea from PCWorld ! it seems that this humming noise is chasing me as well !!! I cant stand it at all .. I wonder what shall I do ! i took it back to pc service support at pcworld and they said it could be the electricity at your place ! i told him i unplugged it and I still hear the same noise ...he got confused then he said it might be the hair on your ears !! well I nder if that is a common problem with all DV 9000 series how comes HP is proud of selling them?? please any advice ..Cheers
  • SPAcer Apr 01, 2009
    Same whirring noise above the keybord on my Paviliondv7-1285dx. Just talked to tech support in India, and they had me take out the hard drive, the dvd player and blow into each, even though I told them the problem came from above the keyboard on the opposite side of each of those. Please, somebody help. The whir is so noisy I have been banned from the room.
  • Anonymous Apr 20, 2009
    its the fan
I have a dv6000 and its makes a insect tlike noise. i returned it and  got another one but that one also made the same noise. so i contacted hp and they told me that the sound is coming from the USB ports, i thought wierd but here is the solution to your problem. go to computer managment (start>right click my computer> manage), click on device manager, select the universal serial bus contollers ( there should be a few roots files that open up), right click a usb root hub and select properties, click the power managment tab, and uncheck "allow the computer to turn off this device to save power". do this for every USB root hub that you have, and the problem should go away. FYI these instructions are for windows XP.
Posted on Oct 13, 2007
Humming fan!......hp dv9000 = poor quality control in the manufacturing process.
I opened my computer up and took a look. What did I find? Where do I start?
On the underside of the keyboard I found 2 human hairs sealed under a solid strip of clear tape. But thats not all folks! My fan was grinding. And why was it grinding you may ask? I will tell you. A white label "Not" centered on the top of the fan blades. Crooked enough to throw it out of alignment.Took the darn thing off. Problem solved!
I also found the sticky side of adhesive tape used to hold down wires with makes a great lint trap. Simple things that can truley harm your computer.
Posted on Aug 27, 2008
After hours of fooling the laptop, I finally figured out the cause of the humming. It was a screw inside the battery housing,closes to the fan.apparently it was to tight.once i losen or removed the humming noise went away.Hope this helps some of you.
Posted on Mar 18, 2010
  • Avaria001 Jun 20, 2011
    I just bought a dv4-3029TX and slightly loosened some of the screws around the fan and hey presto the humming is gone! Thank you so much, I was so worried for a second after just starting it up for the first time :)
AFTER READING THIS FORUM I CAME TO THE CONCLUSION THAT MOST OF THESE PEOPLE ARE FUCKIN RETARDS. ITS THE FAN! ITS A POWERFUL ENTERTAINMENT LAPTOP THAT GETS HOT. IT NEEDS A NOISY FAN TO COOL DOWN. BUY A SONY, PANASONIC, TOSHIBA, PACKARD BELL OR A COMPAQ WITH THIS POWER AND YOU'LL HAVE THE EXACT SAME NOISE! YOU ******* TARDS!
Posted on Jan 24, 2011
I got dv9000 also.. think sum thing got loose inside... make a metalic noise when i tap on the key board.. maybe sum heat shield.....
any one know how to open a dv9000??
whats wrong whit the DV'S
Posted on Jul 14, 2008
  • 99 Answers
Its the fan!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 25, 2008
I had a problem with a VERY loud noise coming from the fan area of my HP Pavilion dv9000 laptop after having it for over 3 years. It was really irritating me, I then looked at the web for similar problems and tried Kevjays solution (solution 13), my computer is now the quietest it has been since i first owned it. NICE ONE Kevjay :-)
Posted on Nov 10, 2010
    Problem Solver:
  • 11 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Clicking sound..... metallic near front mouse pad to left side.. I tried the USB port and clicking but nothing is working.. is giving me a headache... even in mute this happens. Also for 2 days it is recovering data....any solutions
Posted on Apr 13, 2010
Sounds like theres something blocking the cpu fan or the fan is dieing. if you good with taking apart laptops then take it apart and change the cpu fan if not take it in to get it repair
Posted on Dec 05, 2008
Its not a fan, I had the same thing but its actually the processor, It takes to much juice. I upgraded to vista and the noise went away. i did find a piece of software that regulated the power to cpu and the stopped the noise as well but I cant remember what it was called.
Posted on Oct 27, 2008
If you get a faint clicking noise that happens even when the laptop is asleep, then its this really strange virus from the smitfraud family. Get rid of it and the clicking should stop.
As for the grinding noise, I have it too, and it always is worst after the laptop has been on about five hours, so its definitely got something to do with over-heating.
Posted on May 02, 2008
I have a buzzing sound too. It goes away when you turn the screen brightness up to full.
Posted on Feb 24, 2008
I had the same 'fan noise' problem and I tried all the solutions from the internet forums but none worked. After I realized that there thousands of people that had the same problem, I sent my pc back to HP and mentioned to that i will sue them using the 'lemon' law and they replaced my motherboard. It's now working perfectly and quietly.
SEND your notebook back if its under warranty. I not, buy the extended warranty and send it afterwards.
Posted on Feb 06, 2008
    Problem Solver:
  • 16 Answers
It would help to narrow down specifically where the noise is coming from. imo, there is three possible noise sources, fan, hard drive, and sound card. Is it the sound card? mute the volume, see if it stops. Is is a constant hum? the CPU fan would possibly only make a noise once the system heats up, and then not usually hum so much as it is a grinding noise. The hard drive could potentially make the humming noise, since it is easily removed from the bottom side, seems the humming would be louder on the bottom. Here is link to HP support page, download the Maintenance and Service Guide: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=3224049&lang=en&
Posted on Aug 04, 2007
    Problem Solver:
  • 10 Answers
Buddy..!! I am Amazed to see that i am not alone.. me too have DV9000... and i was thinking that its only with me.......well it seems like builtin problem with all of these DV9000 notebooks I think i can compromise with the sound...but if u think u can't stand it then return but leme clearly tell you... its with all of these F***ing DV9000 notebooks
I had the same problem! I solved it! Go to BIOS, find CPU4 and make it disable! It should help.
Posted on Nov 25, 2007
SOURCE:
Tip
HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 | Computers & Internet
    My print screen button doesn't work on my dv9000 and i have tried EVERYTHING
    On my HP Pavilion DV9500 with Win7 64 bit (laptop was new in 2007 and had Vista), I have the same problem, and I press FN-insert/scroll key and this works as the print screen button. That's the function key together with the insert key, which is 2 buttons to the left of the print screen key.
    numberpad on hp dv9000 Page 2 Hardware Canucks
    Aug 08, 2010 | Compaq Laptop Keyboard for HP Pavilion...
    How long is the battery on a HP Pavilion dv9000 supposed to last?
    Laptop batteries will usually last from 1.5 to 5 hours, depending upon the demand, the battery and the use. Sound burns up a lot of juice as does the DVD player so if you're watching movies or playing games an hour is about right. You can purchase a better HP PAVILION DV9000 Battery with 12 cell , it will work longger.
    detail: http://www.battery-center.net/hp-pavilion-dv9000-battery.html
    Dec 04, 2009 | HP Computers & Internet
    How do I removee my keyboard and get a replacent?
    Removing the keyboard can be a somewhat daunting task, until you have instructions accompanied by some good illustrations..
    here is a link to a page that shows how to dissasemble the dv9000.
    http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
    Then when you want to reorder the keyboard..
    Here is a link to a site that offers a replacement for 20$
    http://www.trianglelaptops.com/p-7742-new-hp-pavilion-dv9000-series-laptop-keyboard-aeat5u00010.aspx
    Oct 30, 2009 | HP Pavilion dv9000z Notebook
    Hp dv9000
    HP has identified a hardware issue with certain HP Pavilion notebook PCs, and has also released a new BIOS for these notebook PCs. There is a free repair if there are hardware issues. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=1842189&docname=c01087277#
    Jul 05, 2009 | HP Pavilion dv9000z Notebook
    Space bar missing on hp dv9000 laptop
    hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
    Jun 06, 2009 | HP Pavilion dv9000z Notebook
    Cant find bluetiith on my pc
    THIS MAYBE A FIREWALL ISSUE, MAKE SURE THE SWITCH LOCATED ON THE FRONT OF THE LABTOP RIGHT BELOW THE KEYBOARD IS A SWITCH THAT TURN OFF AND ON THE BLUE BOOTH WIRELESS DEVICE.
    ON MY HP DV9000 IT IS NEXT TO THE RELEASE BUTTON AT THE TOP OF THE MINITOR.
    LOOK IN THE MANUAL OR THE SETUP SHEET THAT EXPLAINS WHAT ALL THE SWITCH AND CONNECTORS ARE FOR.
    ROD
    May 04, 2009 | HP Pavilion dv6000z Notebook
    Replace HP dv9000 keyboard
    This is probably the closest model to your HPdv9000, click on the link and read on! http://www.insidemylaptop.com/remove-keyboard-replace-memory-hp-compaq-nc6400/
    Good luck and have fun!
    Dec 03, 2008 | HP Pavilion dv9000z Notebook
    HP Pavilion dv9000z Notebook Logo
    15,671 people viewed this question
    Top HP Computers & Internet Experts
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
