Need to reset time/date - Office Equipment & Supplies
  • 7,993 Answers
Look for a menu , or a Setup button. Use the arrow keys to scroll the menu options until you find date time.
Manual is available at the Brother Solutions Center. Enter this in a Google search. Choose country, Choose MFC, Choose Model number then download the manual. Manual is also on the CD that shipped with the machine.
Posted on Oct 17, 2013
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Follow the instructions on page 10 of this Quick Start Guide.
Posted on Apr 22, 2013
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
I need help resetting the date and time on my Celestron super weather station. There is a label that says 433MHZ
Hi Richard do not own one of these stations but normally you can obtain instructions on line or try to contact the manufactuer
Mar 11, 2015 | Celestron Measuring Tools & Sensors
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
Aug 20, 2014 | Canon PowerShot Cameras
Fuji s4300...reset time and date
Press the MENU/OK button. Press cursor-left, then select the wrench-SET icon. Press cursor-right, then select the DATE/TIME command.
If you need a manual, you may download a copy here.
Aug 13, 2012 | Fujifilm Finepix S4300 Digital Camera...
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
My date has to be reset every time I turn on my computer. How do I ensure the date and time is memorised thereby avoiding resetting. Thank you.
most of the cases the main reason behind the date time reset problem occurs due to weak CMOS battery on the motherboard. So, you just need to change your CMOS battery on your motherboard to resolve this problem.
Mar 29, 2010 | Computers & Internet
Need to reset the date and time.
press the dataregistration button,press set,use the arrows to scroll down to usersettings,press set again,time&date will be displayed,press set and change the date and time.
Jun 02, 2009 | Canon FAXPHONE L80 Laser
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Apr 08, 2009 | Toshiba DKT3010SD Corded Phone
Date & time reset
try and enable automatic update of time and date in the settings..
Nov 02, 2008 | Nokia 6300 Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
32 people viewed this question
jasbo
jasbo
