Question about Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios
With navigation system
I just buy a factory radio with navigation system for honda accord 2003 the problem is the radio fix perfect but there a blue plug in the back of the radio that i suposed to turn on the monitor but dint come with the radio so mean that i can use the monitor even i can put the password to turn the radio cause the monitor dosnt turn so i just can turn the air on auto and no else apreciated if you help me cause i spend $700 dollar in this jus to change the look inside and i dont want it loose the money thanks apreciated
    Scholar:
  • 145 Answers
What model 2003 accord do you have?
Posted on Aug 09, 2009
My antenna on my 1990 honda accord stopped working after I installed a new radio
BAD CONNECTION? DID YOU PLUG IT BACK IN? OR DAMAGE WIRE? OR PULL OUT FROMM BEHIND DASH
Mar 14, 2013 | Honda Cars & Trucks
How can I fix the light display for the radio in my 03 Honda Accord?
The 2003 - 2005 Accord CD/Radio unit is prone to display failure. Honda had issued a TSB some years back but you may be beyond the warranty period. We repair this display issue. Check it out: www.autoclockrepair.com
Jul 14, 2010 | 2003 Honda Accord
I have a 05 accord ex with navigation. my dog
You will need to remove the radio to get the serial number from the radio. The radio most likely can be repaired alot cheaper than a new one. You can click on the link to this Company to have your radio repaired http://www.hitechserv.com/ they repair all radios but you will have to have your radio removed and shipped to them so they can repair it. I have had electronics repaired by them and they do an excellent job. Give them a call and let them know what is broken so they can give you a rough estimate.
A new radio from Honda is close to $3000 http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgry2=2005&catcgry3=2DR+EX+%28V6+NAVI%29&catcgry4=KL5AT&catcgry5=NAVIGATION+SYSTEM
Jun 16, 2010 | 2005 Honda Accord
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Jun 08, 2010 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
2004 Accord with nav, radio code
take to a garage and get a diagnostics or buy a new raido i have one for sale ;-)
Apr 13, 2010 | 2005 Honda Accord
My radio needs a code
"i have a 2004 honda accord my radio needs a code"
I had the same problem on my Honda Accord.
After several attempts to fix and many error messages I called a Honda house and the lady in service said "No problem". She then asked for the two codes listed by using the procedure described above (the "U" and "L" codes which both contain 4 digit numbers following the U or the L.
I gave her this and she "looked it up".
In a couple of minutes she returned with a 5 digit code which I immediately tried.
Of course it didn't work because it only has room for 4 numbers.
I went thru the battery disconnect reset (for 5 minutes) and while that was going on, I remembered that the code for the navigation system was located by another service tech once before.
All he did was pop the top off the fuse panel under the hood.
On the cover, along with the fuse identification was a white sticker with some numbers on it.
One of the typewritten numbers had a "N" written with a pen on it.
Another number was 4-digit and had a "R" in blue ink, like the N written on it.
I thought "If N stands for navigation, would R stand for radio?"
The rest is history.
When I plugged that number into the radio in the code entry mode - everything started working.
If I hadn't seen that tech open and retrieve the navigation code, I never would have related "N" and "R". The under hood fuse box is located on the driver's side up near the windshield.
May 24, 2009 | 2004 Honda Accord
2003 Accord. Navigation/radio/display system does not load.
I've reads post here suggesting disconnecting the battery for one hour. Couldn't hurt to try it.
Also try ejecting the Navi Disk, inspecting it for any damage, wait a few minutes and reinserting. The disk contains not only the navigation Database, but also part of the operating system.
DO NOT TRY INSERTING A OLDER NAVI DISK OR ONE FROM ANOTHER VEHICLE, THAT COULD DESTROY THE NAVI UNIT!!
If you need a new Honda Navi Disk, order it direct at https://www.hondanavi.com/Hondadvdsales/naviorder.php
Good Luck
May 05, 2009 | 2003 Honda Accord
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
We have a 2004 Honda Accord Sedan, light quit working on the radio, dash lights still work, and when the sun hits the radio display just right you can see it's still got the right info on it, it just...
This is a common issue for 2003 and 2004 Accords without Navigation. This issue has been brought upto Honda America and has extended the warranty for this issue to 7 years of 100,000 miles which ever comes first.
Feb 02, 2009 | 2004 Honda Accord
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios Logo
198 people viewed this question
Top Pie Car Audio & Video Experts
xxxxxx xxx
Are you a Pie Car Audio and Video Expert? Answer questions, earn points and help others
