Question about Garden
Tb575ss what size is the fuel lines for this trimmer?
boscia
  • 163 Answers
SOURCE: starter rope on Troybilt TB575SS
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Posted on Nov 29, 2008
SOURCE: how to remove(unscrew?) centrifugal clutch
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Posted on Jun 23, 2009
  • 165 Answers
SOURCE: I have a Craftsman trimmer mod# 358795121. What size fuel lines.
Sears has ample parts for repair.
Posted on Feb 27, 2010
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Posted on Apr 09, 2010
  • 61 Answers
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Posted on Apr 14, 2010
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
Fuel line diameter mcculloch trimmer eager beaver 2
According to Randy Duncan Ebay site(Randy's Engine Repair) the fuel line is 3/32" inner diameter and 3/16" outer diameter for the non-primer bulb side of things for a McCulloch chain saw. It is a common size, apparently, but is not listed in the User manual as such.
Apr 30, 2012 | Garden
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
May 29, 2010 | Troy Garden
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
I have an old 720r trimmer plus ryobi. need to replace the fuel lines. what size is needed
Im not sure on the size I always pull the old ones off and find the matching size,I will however tell you a good trick for installing new fuel lines on trimmers. Get a fine piece of metal wire about six inches long or so (like mig welding wire). You want to take the end of the new fuel line and with snips cut a 45 degree angle so it kind of comes to a point. Next poke the wire through the end you cut and twist it. Finally use the wire to pull the new line through.
Aug 09, 2009 | Garden
How to remove(unscrew?) centrifugal clutch assembly from engine shaft of TB575SS troybilt 4-cycle weed trimmer?
Jun 23, 2009 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
