Question about Epson Stylus Photo R300 InkJet Printer
Epson R300 Printer doesnt print through paper it constantly jams and wont feed thru properly.Ive tried virtually everything and it still wont feed properly it will make an attempt then it just starts to jam. I can print on CD/DVDs fine but it wont feed paper. PLEASE HELP!!
  • nrentinc Mar 12, 2009
    Tried that still have the problem. Ill keep trying tho thanks for the help.
  • nrentinc Mar 17, 2009
    can anyone else offer any other solutions. Please and thanks.
  • 163 Answers
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Posted on Mar 12, 2009
Paper feeds ok but after a second it advances an inch then get the error paper jammed. wont print please help
When turn on status ok, but when star to print, it feed paper then jammed? Problem with head carriage. Check chip and connector chip at carriage. Try to use another ink tank.
Jun 25, 2009 | Epson Stylus Photo R300 InkJet Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Cd printing problem
Hi there
I had a similar problem and could'nt figure out why the cd tray was not going all the way through. Then I realised that I was being dense and had the printer too close to the wall and the tray could'nt feed "through" properly. Check your distances. Maybe you're not as dense as me but check just in case.
Regards
Tom
Aug 27, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printer not loading paper.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 18, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
224 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
